Garden Logo
Posted on Oct 06, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Riding mower problem
I bought a used riding mower a few weeks ago. I test drove it. It seemed to have a hard time cranking over but eventually did. Once I brought it home I started it once a day, for a few days until I could take it up north to my cottage. One day it would not start, I ordered a new starter, installed it and nothing. The mower won't even try to crank over. Any help
Thanks
Anonymous
Level 2:
Scholar:
  • Expert 62 Answers
  • Posted on Oct 07, 2008
Anonymous
Expert
Level 2:
Scholar:
Answers
62
Questions
Helped
75068
Points
150
What is the name brand and model? On most riding mowers there are several switches that must be actuated before it will start. First, make sure that blades are disengaged. If there is a handle that engages and disengages them, you might try holding it in the dis-engage position in case the switch is out of adjustment. There is probably one under the seat also. This switch kills everything if you are not sitting in the seat for safety reasons. Also, make sure the parking brake is set, and the gear is in neutral, and not forward or reverse. Also, you should check the battery. It is possible that you left the key on by mistake and drained it.
Hope some of this helps.
C
Motor just shut down, drove about 5 feet
Wow almost sounds like the Timing is way off.
Today's Lawn equipment.. as you say.. nice colorful ornament.
Jan 04, 2014 • Garden
Hard to start after it sets up for 4 to 5 weeks
gas is only good for small engines for 30days use fresh gas
My 12 horse brigs and straton riding mower keeps discharging its self what do i do
"testing" with a fog lamp wont prove anything other than charge state! You need a load tester!
Check the fluid level inside the battery, Your starter may be going bad.
May 26, 2012 • Garden
I bought a john deere riding mower less than a year ago. i used it last season without any problems. I think the last time i used it, was in august 2010. winter came about, the grass wasn't growing, so...
First, I've had a motorcycle for almost 50 years and have never drained the gas. At one point it was not used for 3 years. It started, I added gas and it ran fine.
Second, next time you are running the machine and it begins to stall, immediately loosen the gas cap. If it starts to run good again, drill out the air vents on the cap.
Gary
Mar 09, 2011 • Garden
1helpful
Engine won't crank on a 18.5hp 4000. I checked mechanical interlocks, charged battery and put in fresh gas. New carb and fuel lines put in last year. When I turn the key, there is a click and the ammeter...
The starter solenoid is most likely the clicking you hear. It has contacts inside which go bad. These are about $10 and easily replaced. Just follow the + battery cable and it will lead you to the solenoid.
No power
I think you should check the charging system. You said you replaced the battery a few weeks ago. Even with the charging system not working, the battery might have enough power for a dozen or more start-ups; but using the lights may have drained what power was left. Get or borrow a battery charger and charge your battery. If mower then seems to be working fine, measure the voltage across the battery when the mower engine is running at normal speed (not idling). It should be 13.5 volts or more if the charging system is working. 12 volts or less means it's probably not working. Either test or replace the regulator/rectifier. Please rate me if you think this helped, thanks!
Top Garden Experts
Jay Finke
Jay Finke
john h
