Have a new razor drifter go kart and it only worls for one small lap and looks as if it runs out of battery but is new and the battery shows full at the beggining and quickly turns to low
Well most likely, your batteries are weak. When the charger shuts off, the batteries have stopped taking charge, but they're not necessarily at full strength, especially if they've been sitting for a while without being charged. Connect the wires from the power switch together and try again. If it works replace the switch. If not, turn the motor shaft both ways. If it makes clunking noises, it's cooked. Otherwise you probably need batteries. Ive never seen a throttle or controller cause slow operation. And also always keep your tires pumped up.
If the battery is gone(bad), sometimes it will show fully charged (volts are good).. but it has no amperage to "push" the voltage... It takes amperage to make the drifter move... (time for a new battery)... they don't last long...
The batteries should be 2 x 12v giving an output of 24v anything less than this the Razor Dirt Quad will not run. always make sure you buy genuine Razor replacement batteries.
replace thumb tab throttle. part is $12.99 from razor. go to razor site to order. i had the same problem after my daughter drove it over a bumpy sidewalk.
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
