Wow no country stated, oops, they all be different.! (laws and voltages are not the same world wide !)
the PC run on low voltage. only
called a power pack, that converts 120 to 250vac to 19vdc
on most HP. but HP bought compaq in 2001?
so the DC voltages can very on the early ones.
why not buy matching power pack on ebay.
do not wire it to AC 120vac, are you in USA? if not other line voltage are even higher, in South America,240vac is common.
if hot wire it ,i promise it catches fire.! how is that. for facts.
this is the US cord only, HP sold 17 cords for 17 matching counties. the USA p/n HP is : cord only.
255135-001
now lets EBAY this. power packs, and cords
https://www.ebay.com/sch/i.html?_odkw=255135-001&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.H0.X+Compaq+Armada+1700+Notebook+power+pack.TRS0&_nkw=+Compaq+Armada+1700+Notebook+power+pack&_sacat=0
From the specs on this laptop it is unusual as it has a built in power supply unit . Hence the three prong power socket on the laptop. This flee bay link below shows the actual internal power supply however it does not state what the supply in voltage is rated at . It may work on both ? It may need to be switched depending on the power supply. If may need a replacement internal power supply board to match your countries power point supply voltage and frequency.https://www.ebay.com/itm/COMPAQ-ARMADA-1...
You will have difficulty buying it from HP as they took over compaq . It is listed on HP spare parts websites as a discontinued spare part .
This model has a 110v or 220v power supply built into it.
Make Sure it the matching required voltage on its case if you plug 220v power point into a 110v rated power supply inside the laptop it will let out lots of smoke and stop working !
The part number is 255135-AA1
USA ? https://www.ebay.com/p/3-Prong-18awg-AC-Mickey-Mouse-NEMA-5-15p-to-C5-Laptop-Power-Cable-Cord-15-Feet/1348595046?iid=252155340421
or
https://www.amazon.com/yan-3-Prong-18AWG-Mickey-Laptop/dp/B0722GF9DB
suggest search on
3 Prong 18awg AC Mickey Mouse NEMA 5-15p to C5 Laptop Power Cable Cord
transformer?
that is good word, as it has power pack
it really a AC to DC power-converter pack.
never never ever try bypass any power pack made. or you will get on fire or shocked.
even *****.
my guess you lost the cord
you can buy a cord
or even a whole new pack for it for dirt cheap.
at fleabay
SOURCE: Compaq R4000 Power Issue
poor deb---
are you referring to the fan assemblies that go all the way across the back , including over the jack? It comes out in one piece, there are screws at the forward and kind of hidden and hard to get to without completely disassembling the entire thing. I think you'll see that the little piece that comes up and over the jack is part of the fan assembly.
The hp website has a service/hardware manual that has blow-apart illustrations in it...that's how I found it, and you will too.
it's called---
HP maintenance and service guide
part no 33540402-003
SOURCE: Notebook power problem
make sure the new A/C adaptor and battery are working correctly.then check the charging circuitry or power distribution in the laptop
This can be caused by:
1.The monitor is not connected properly.
2. Bad hardware
Verify that the monitor is properly connected in the back of the monitor as well as to the back of the computer.
If the connections are OK it means that monitor or the video card is probably damaged. To test which component is dameged connect a different monitor to your computer or connect your monitor to a different computer.
If the other monitor works on your computer it means that your monitor is bad and if your monitor works on another computer it means that you probably have a damaged video card.
Let us know how things turn out and don?t forget to rate the posting.
SOURCE: compaq presario M2000 power cord won't charge my laptop
please try this
First u remove battery from ur laptop and connect power adpter
check laptop power on
if laptop is working u will change laptop battery
otherwise u could try another power adpter
SOURCE: My power cord is loose. It plugs in and charges,
Hello !
If I'm understanding you correctly, the wiggle is from the laptop. Sounds like a problem is about to happen. Your Presario has a loose power jack (connector inside the laptop). It is a part that can be replaced.
If you need further info, let us know.
Hope this helps.
Testimonial: "Thanks, is this something that is covered by my waranty?"
