These are the possible codes and the reason for occurence of this code in your copier
010-150, 155 -Too much or not enough paper in duplex tray
010-300 --Fuser thermistor,
010-302 --Low fuser temperature ,
010-304-- Bad fuser temp,
010-308 --High fuser temperature or open thermistor,
010-310 --High fuser temperature ,
010-312 --Fuser not up to temperature after energy save,
010-314 --Fuser problem ,
010-320 --Fuser web finished ,
010-330,327, 335, 340-- Exit switch, vertical sensor switch actuated when power is turned on
010-150, 155
10-300
Fuser thermistor
10-302
010-304
Bad fuser temp
10-308
010-310
010-312
010-314
Fuser problem
010-320
Fuser web finished
010-330,327 335, 340
There is a problem with the fuser thermistor in that machine.
You can replace the fuser module you can try looking up on google a business called 'The parts drop" call and see if they can sell you just a thermistor. That's not an uncommon problem. Some of those fusers were made with intermittent thermistors.
Also, you can go into the machine setup and turn the power save OFF. A new machine will come with the power save set to 5 minutes and it will make you crazy.
