I can not switch the player on and off. Switch on side does not work. I kept pushing buttons and at one point it turned on. It plays fine, but now I can not turned off, it only stops and shots off if I open the lid. What is wrong? Is there a combination of key-strokes for turning the device on and off? Your help is appreciated. Thanks. lou
SOURCE: Zen V in key locked mode when it starts, screen turns black after a while
install new firmware
SOURCE: How to unfreeze mp3 player
We have a toshiba gigabeat f20. today it worked fine, listened to it for hoursbefore turning it off. turned it on within a hour to play it and got a blank screen. nothing in the environment could have caused this. battery had been replaced a week before. so, took the case off to opened it and take a look. realized that one of the plug ins for the screen had come loose or slightly lifted inside. it did not totally unplug, just not pressed down tight. pushed it back in. put the case back on. hit the power button and it's back on, nothing that had been previously loaded was lost.
SOURCE: Nextar ma570 mp3 player wont turn on
I had the same problem happened on my MA570. I finally find that it is easy to be fixed.
The problem is the lost of the Drive software in the MP3 unit for whatever reason. Use the mini CD that comes with your MA570 when you buy the player in the package. Put this mini CD into the PC. PLug your MA570 through the USB with the PC as a removeable device. Clikc the install software on the mini CD and install it into your MP3 player (for example device F:). After you have the new driver installed, you will be able to turn on the MA570 again. Let me know, if this still not work. It works for me.
