Washing Machines Logo
Anonymous Posted on Jan 03, 2012
Wfw8300 can door be reversed - Whirlpool Washing Machines
  • Anonymous Jan 03, 2012
    also can door be reversed on wed8300sw04
Steven Clarke
Level 2:
Sergeant:
  • Expert 222 Answers
  • Posted on Jan 10, 2012
Steven Clarke
Expert
Level 2:
Sergeant:
Answers
222
Questions
0
Helped
141485
Points
567
The washer door can NOT be reversed the dryer can.
2answers
How do you reverse the door
If its a side by side like the one showing on your post, I doubt you can unless there is a spot showing for under the door, and the water and electrical lines are long enough to switch.
Why is my garage door suddenly reversing when going down?
Deb, that reversal is a child safety device - if the bottom edge of the door detects contact with any object, it'll immediately reverse so it doesn't kill a child. Or a cat, dog, whatever.
The opener mechanism should have a stop switch that prevents the door from closing hard against the floor - that stop switch needs to be adjusted so that the door will stop JUST before hard contact. That'll take care of it "bouncing" off the floor & reversing. As to it reversing before it touches the floor... examine both guide rails closely to see if there's any obstruction that the door's bottom edge may be contacting to trigger the child protection reversal switch.
Reverse door
Good morning friend, I appreciate your post!
I see you are trying to reverse the door for your Frigidaire top mount refrigerator, FFHT2117PS. I have successfully located your manual and it provides step by step instructions on how to reverse your doors. Hope this helps. -Matt
Frigidaire Manual Search Results
2helpful
How do you reverse the front door on a Kenmore HE4t washer?
The Kenmore HE4T washer does not have a reversible door. The matching dryer would have a reversible door.
Some newer washers do have a reversible door but it is still a very small number of washer that allow you to reverse the door.
You can not reverse the door on an HE4T washer.
2helpful
What is error code f 21 on a whirlpool duet sport wfw8300 3.8 cubic washer?
This means that the drain pump is clogged. Tip the machine back and remove the three screws on the bottom panel. The pump has a filter inside. Pull the filter out and clean it, it will fix the issue for sure!
Whirlpool model # wfw8300 duet washer door will not open with wet clothes in it-how do I unlock door?
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Front Load washer won't start
according to site an f-01 relates to a CCU issue, remove power for 2 min and try to reset, if not check wiring to CCU(central control uint) all in tact?? replace CCU
Reverse Door
You can't reverse the washer door, only the dryer door.
They don't make the washers reversible because the door latch and wiring harness would have to be relocated to the other side. It just isn't practical from a manufacturing standpoint.
Sorry, Mike
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
