Actualy i wanna know that how to block a website by router.i m using beetel 450tc1 adsl2+router on airtel broadband connection.please give me solution if is it possible.
SOURCE: BEETEL 220BX ROUTER
First login to your Router using default username and password
2. Click on WAN on the left side menu
3. You'll have options to add or remove configurations.
4. Please select and remove the bridge config as BSNL does not support Bridge.
5. Please click edit on the existing PPPoE Airtel Configuration
6. Set the VPI=0 and VCI=35 (for Airtel it would be 1,32) and click next
7. Select PPP over Ethernet (PPPoE) and encapsulation type: LLC/Snap Bridging and click next
8. Enter the following details:
PPP Username: Your bsnl username (no need to add dataone.in)
PPP Password: Your bsnl password
PPPoE Service Name: DataOne
Authentication Method: Select CHAP
Click Next
9. Check the Enable IGMP Multicast Option
Check Enable WAN Service Option
Enter the Service Name as Dataone
10. Click Next and Save. You should also save and reboot your modem.
If doing the above does not works, check if you have anything set Under TR-069 Client and remove all entries in this section however it may not allow you to save so you may just put the ACS URL as ( it won't accept this field to be blank so just enter any thing, I entered http://bsnl). Save and reboot the router. Should be online now.
let me know if anyone benefited from the above information - [email protected]
SOURCE: Sir i have reliance broadband
please explain better whats a reliance nd?
by the way you need to connect the dsl port to the phone line
wire a pc to a lan port and boot you will get an ip address
then you can run a command prompt type ipconfig
that will give you a the default gateway address thats the router address
type that address on the browser ,
that will take you to the router log in page
insert name and password for router
if has a configuration wizard follow that for the PPPOE settings or dsl settings put your client ( username ) and password for the internet connection ( provided by internet provider reliance ) save the settings reboot both the router and PC an that should do it
