It was working fine all of sudden, it has stopped taking pictures, ie when I take the pictures but blank screen comes on to display screen on quick review and same on the Play mode as well. It is a new camera. What could be the issue? and how can I fix it? Thanks
SOURCE: nikon d90 - can't take the picture
You just found the Nikon D90 F-- error message solution!
I had the same problem with the Nikon d90 F-- error message which drove me nuts!
I called Nikon, they walked me through a lengthy reset procedure which didn't work. After spending a few hours researching online, I found the answer.
It is not the memory card or nor a defective camera body. The lens does not need to be rechipped.
The F-- error means the camera is unable to communicate with the lens and is caused by a poor connection between the ground contact pin on the lens and the metal mounting ring on the camera. Most people buy the camera, install the lens once and then encounter the error. This one time lens installaiton does not give the contact point a chance to seat itself properly. You will find that if you hold down the lens release button and twist the lens as if to remove and reinstall the lens about 10 times that the problem will disappear. You don't even have to actually pull the lens away from the body, just press the release button and twist on and off and allow the friction to provide a better electrical contact.
Too bad Nikon doesn't tell their customers about this simple fix. Other than that, great camera. Good luck.
I had this same problem with mine for weeks after I got it and it was driving me insane! Then, a friend said that the lens might not be on properly so I removed the lens and re-attached it- and voila, problem solved! I had the same issue where the info panel said F-- and depressing the button did nothing. So, I'd suggest looking at your lens, detach it, make sure there is no dirt or anything where it attaches and re-attaching it very carefully. I hope this helps!!!
SOURCE: Nikon D90 takes pictures, all pictures are black!
I think its your CCD. If its new take it back. Nikon will fix it for free
SOURCE: SLR Camera : Nikon D90, dropped from 5ft and landed on Road
There is an almost certainty that your mirror and shutter is going to experience problems in the future. Any fall of that nature is SURE to jar the shutter and the mirror very badly. The shutter is probably damaged already. Go out in the bright sun and shoot on shutter priority at the highest shutter speed (I think the 90 is 4000 /s?) and see if the shutter makes a stuttering noise...Also go into your menu and set the mirror to "Lock up" (for cleaning purposes), if both of these things work ok, you should be ok for a while. But do not depend on the camera for anything really important such as weddings unless you have a backup camera...
