Model # M73-625 AP Quit working and does not vibrate.
SOURCE: Variable speed quit working
You would need to replace the switch, give me a model number and a location with zip code and I will try and find one locally for you, Its not that hard
SOURCE: Zephyr Savona range hood quit work on low spds-hi still works
Motor Speed may not be working and this means the either the motor is bad or switch is bad for motor Low Med Hi Switch
SOURCE: i have a chevrolet impala 2002, my air
No. Most likely it is the blower module. It is on the passenger's side lower part of the dash panel.
SOURCE: The speed reading on my epic 55o treadmill quit
Under the motor cover, on the left side mounted on the frame is the speed sensor.
It is a little black "bullet" shaped thing clamped to the frame with a wire wrapping around the frame to the electronic board. It may need to be adjusted. Move it as close to the pulley as possible without making contact. If it still doesn't work, inspect the pulley for the 1/2 inch round magnet. It is mounted on the pulley. If it is missing, it may be attached to the metal frame someplace. Place it back into the holder on the pulley and try the treadmill again.
If you still have no speed reading, the sensor will have to be replaced.
Testimonial: "That worked, thanks!"
SOURCE: wipers quit working low speed & delay, wont park. work fine high speed. have changed sw, didnt help
When they won't park it's 99% need new wiper motor
