Heating & Cooling Logo
A
Anonymous Posted on Jan 03, 2012
Operating manual for patton POH2420 - Patton POH2520-U Oil Filled Radiator Heater
How can I order the manual of Patton #POH2420?
Unfortunately you can't. These are made overseas and badged to whomever sells them. The manual for the 9000 model is available, but not yours. This may be the closest?
http://www.useandcaremanuals.com/pdf/WOFH7167.pdf
https://www.google.com/search?q=Patton+POH2420+manual
1helpful
4answers
Blade for Patton Stand Fan Model 1010-MP1
u can get a replace blade from hard wares and fan shops also try ebay and oztion
Can I buy a heating element for this heater?
On google
Patton replace heating element Heaters Questions ... - Fixya
www.fixya.com > Forum > Tags > replace heating element > Heaters
Patton heaters replace heating element related questions and answers. Ask yourPatton ... I can't seem to find a phone number for the manufacturer to call for parts. Any help? ... Question about PQH307UM Electric Utility Heater. 1 Answer ...
Patton PQH307UM Electric Utility Heater Quartz elements ...
www.fixya.com > ... > Patton > Patton PQH307UM Electric Utility Heater
Patton PQH307UM Electric Utility Heater, quartz elements replacement related ...Element. Where can I find replacement quartz tube heating. Element Infrared ...
Patton PQH307UM Electric Utility Heater Element ... - Fixya
Patton PQH307UM Electric Utility Heater, element related issues. Get free help, solutions & advice from top Patton experts. ... The heating element is above the thermostat, and all you will see is a round disc with two wires attaching to. Ad.
Patton PUH680-U Utility Heater Replacement fan motor ...
I want to unlock my phone Patton
You need to include more information: Model number would be helpful. You could also try checking your product manual and seeing if they list a way to unlock the phone.
1helpful
Will the patton electric heater significantly raise my electric bill
1500 watts is 1.5 kilowatts. Run it for 1 hour and you have 1.5 kilowatt hours. My electricity costs .08 per kilowatt hour so, when I run my 1500 watt space heater, it costs me a whopping .12 per hour to operate. I can afford 12 cents per hour, compared to oil at $3.50 per gallon and a burner that burns up to 3 gallons per hour.
Is there a recall on patton heater mod puh9000.mine shorts out? thank you
Yes, there is/was a recall on some Patton Heaters, but I don't recall if your model # is one of them. For more info search Google for Patton Heater Recall Notice and you'll find the correct site.
Any idea where I can get replacement metal fan blades for a Patton floor fan?
I'm not all up on Patton Model#s, but this is an older unit, correct? You may try contacting Patton (Owned by Holmes now so you may have to go through them)
If they cannot help you, try www.dtvintagefans.org There's collectors there that may have parts fans that they may be willing to sell a blade.
Alternatively, you may try Grainger, as they sell an assortment of blades. You will need to match a blade to your motor though, which should be fairly easy as the Patton fans use a common McMillan motor which most attic fans also use.
4helpful
Looking for a phone number to contact PATTON SPACE HEATER COMPANY
Patton at l-800-528-6600 ext. 1722 (Arizona: l-800-352-0458 ext. 1722; Alaska l-800-528-0470 ext. 1722)
Top Patton Heating & Cooling Experts
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
Paul Carew
Are you a Patton Heating and Cooling Expert? Answer questions, earn points and help others
