You can download the manual here:
http://www.farmprotractors.com/hdcmanuals/PW2200-03435.pdf
It is probably the same manual that came with the unit.
As far as pressure... hook up the water supply hose and turn on the water supply. Let the supply hose purge all of the air out. Then turn off the water and connect the high pressure hose. After that turn the water supply on again with the engine off and squeeze the wand trigger. Make sure all of the air is out of the high pressure hose. Then start the unit...
Once the engine has stabilized rapidly squeeze and let go of the wand trigger several times. Your exersizing the bypass / unloader valve spring. By this time you should have good pressure. If you have owned the unit less than 90 days and your sure you have a warranty issue use this link to contact the company:
http://www.homier.com/contacts
Contact Information:
Homier Distributing Company, Inc.
84 Commercial Road
Huntington, Indiana 46750
Hours of Operation:
M-F 8:00am - 5:00pm EST
I note they do NOT include a phone number on their contact page but do state empatically that warranty contact should be made via email
[email protected]
You will also need a warranty form here:
http://www.homier.com/return-authorization-form.pdf
Some of these units have a sliding assy on the wand that slides toward the ouput nozzle for adding soap / chemicals. If the slide is not pulled back toward trhe wand and locked into place you will not have any pressure either.
It appears from reading the manual that this particular unhit had 2 different nozzles. One for chemicals and one for high pressure. Plese make sure you have the high pressure nozzle installed. The BLACK nozzle is for chemical use. (page 5 of manual link above)
The red, yellow or white nozzles are all for high pressure with different spray patterns.
This is about the best I can do for you Ron. Hope it was helpful.
Kelly
