Salter 3007 Aquatronic Digital Scale Logo
Posted on Jan 03, 2012
How do you change the batteries on a Salter model 3007? i changed the batteries and it isn't turning on.
5 Related Answers
Anonymous
  • Posted on Oct 18, 2009
SOURCE: Reset digital bathroom scales
I cannot reset my digital scale to lbs. it is a conair ww body mass scale
Anonymous
  • Posted on Oct 20, 2009
SOURCE: The display on my salter bathroom scales is
I held the two arrow and set buttons together for a few seconds and it cleared
awa13
AWA
  • 78 Answers
  • Posted on Mar 21, 2010
SOURCE: Salter kitchen Scales Model: 1041SVDR won't turn on.
This sounds very typical of kitchen and postal scales. I know you don't want to hear this, but this basically means it is time to replace your scale with a better scale - perhaps no longer giving Salter your business..
Anonymous
  • 10865 Answers
  • Posted on Mar 26, 2010
SOURCE: Salter 9001 bathroom scale stopped working
Hi Pete. I don't keep receipts either : ^ )
No that I am done commeserating, try this. Remove the batteries. Use the eraser end of a common pencil to scrub and clean the battery contacts inside the battery compartment. Also pull the contacts a little closer to the surface if you can. Then reinstall the batteries and you may be up and running.
Please rate my answer as verey helpful thanks. Joe
LaidlawUk
  • Posted on Jun 28, 2010
SOURCE: Kitchen scale, Salter, model 2006: change batteries
The 1 part just slides off.
Is my scale calibrated. When I turn it on it first shows 8888 7/8, then it 0/0g
Take a ten pound bag of sugar and calibrate the scale to read 10 pounds.
3helpful
My Salter Electronic scale (3007) got soaked and is giving incorrect / unstable readings. I am trying to take it apart ASAP to dry the board, contacts, etc. but cannot work out how to detach the weighing...
The weighing pad mates with a circular metal plate underneath and needs to be rotated clockwise to unclip from the metal plate. Peel back the lower right corner of the instruction label on the bottom. This reveals a hole through which a philips head screwdriver needs to be inserted to loosen a screw which then allows the weighing pad to be rotated. The screw only needs to be loosened, not removed.
2helpful
I have a Salter 307 kitchen scale. Are there any instructions for disassembling this unit? Removed 6 + 1 screws and I still cannot open the unit. Please help!!
How to open up the Salter 3007 Aquatronic Digital Scale:
1. Look for a hole (covered by a label) on the bottom of the device, not far from the L-R centre line, and about 1-3/4" from the front. Peel back the label and use a small cross-head screwdriver to loosen the screw that can be seen though the hole (needs about one turn, no need to remove it). Place the scale upright, and rotate the weighing pad slightly in a clockwise direction. This will disengage the tabs on the plastic pad which hold it to a metal base, so that it can be lifted off. 2. Remove the six screws recessed around the bottom of the scale. 3. Place the scale upright and gently "snap" apart the top and bottom shells (catches molded into the left and right ends). Be *** VERY CAREFUL *** when doing this as the display is held in place on a plastic bridge by the upper shell. When this is removed the display is loose except for a flexible plastic printed connector strip (which links it to the circuit board). It is *** all too easy for this strip to break away at one end or the other ***.
5helpful
3answers
10helpful
I changed the battery on bathroom scale Salter 987
I had the same problem with my Salter 987 scale. Pull the battery out for about 10 seconds and put it back in. Then push the scale once so it turns on. After the blinking stops, push it once more. The scale will now zero itself. After the scale has zero'd itself it may turn off after a brief moment. It's now ready to use normally. If you're standing on the scale when it's trying to calibrate to zero, it will assume your weight is zero. Don't stand on the scale after replacing the battery untill you first complete the steps listed above.
Top Salter Health & Beauty Experts
vince
jws1013
Ngoro
Are you a Salter Health and Beauty Expert? Answer questions, earn points and help others
