You can get instructions by going to http://www.genevawatchgroup.com/, click on customer service on the menu on the right and then scroll down until you reach Tommy Bahama.
Just got one, and haven't lost the instructions yet. First, the 4 buttons are:
S1 - at 4 - Lap/Rst S2 - at 2 - St/Stp S3 - at 8 - Mode Light - at 10
Watch Control Normal Display: Hour, Minute, Second Push S1: Alarm time in Hours and Minutes Push S2: Month, Date S3: Change function
Alarm and Chime In Normal Time Hold S1 and the alarm time will be displayed. Press S2 once and Hourly chime will be on. Press S2 twice and Alarm will be on. Press S2 three times and Chime will be off. Press S2 four times and Alarm will be off. Press S1 and display will change to normal time immediately.
Setting Alarm Time In normal time, hold S3 for about 3 seconds, the hour digit will flash and is advanced by pressing the S1 button. Then push the S2 button to change to minutes and change those by pressing the S1 button as above. Push S3 to return to normal time.
This LUPO anion watch emits negative ions and infrared which make you calm. It soothes and relaxes your mind.
How to set the time and date:
This unique watch can display month, date, time & minute.
1.Press A button twice. (Date and Time displays when press once)
2.When the month figure appears, press M to set the month.
3.Press A button once again, the date figure appears and press M to adjust the date.
4. Press A button once again, the hour figure appears and press M to set the time.
5.Press A button once again, the minute figure appears and press M to set the minute.
When you adjust one of among the month, date, time, minutes, just keep press A button until the desired figure appears and press M to adjust. Press M to see the date.
Generally A button is to select the function. (Month, Date, Time, Minute) M button is to adjust the function.
Hi Thanks for using FixYa. To
adjust the date and time you’ll need to follow these instructions---
To wind the Movement:
With the crown in position 1, flush against the case, turn the crown clockwise, completing approximately 15 to 20 revolutions, then gently but quickly move the watch back and forth several times to start movement.
To set the Time:
Once the watch is running, pull the crown out to position 2 and turn it in either direction to set hands to desired time, then push crown back in to position 1. For more information you can
see this manual--- Tommy Watches Operating Instructions Please do accept the solution if the issue is
resolved or else revert for further assistance. Thanks Rylee
Press the mode button 3 times. Use the lap/rst button to switch to the min/hr/date field you want to change. Use the st./stp button to change values. When finished, hit the mode button again.
Hi Junell ,you can't pulled out the crown,because it is threaded.First unthreaded it before you pull,first pull is for DAY/DATE adjustment.Second or full pull is for Hour / Minute setting,that's all.Feel free to ask and post a message,so i can assist..
