SOURCE: Microwave LG intellowave
We bought a microwave from a 'seconds' store, minus the manual. Following the advice given above I found the model number and search the LG site for product manuals.
The site isn't intuiative, but if you are patient you can find the manual in PDF form and download it to your computer.
Thanks for the help MicrowaveSvc
SOURCE: Want a user manual of a microwave oven
L.G. / Goldstar owner's
manuals can be downloaded here.
If it doesn't show up in the search, I would call or e-mail them via the CONTACT US link at the top right.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
SOURCE: microwave doesnt heat food
Microwave not heating problems are the result of one or more of the following problems -
1) Bad fuse
2) Bad diode
3) Bad capacitor
4) Bad transformer
5) Bad magnetron.
You would need to have special equipment to test the 2nd, 3rd, and 5th items.
Reply back of any other questions/help you may need.
SOURCE: my lg intellowave microwave will not work
This
is usually caused by either a bad door switch, a loose door switch
mount (which are pretty simple problems to fix) or
occasionally a
problem on the control panel.
Even though a door
switch clicks, it may still be bad inside.
Door switch
or mount trouble is usually caused by slamming the door or by opening
the
door while it's cooking without hitting the Stop pad first.
There are
plastic mounts inside the microwave which hold the door switches and
onto which the door latches lock when you close the door.
The screws on these
mounts may be loose. If they get too loose, the switches will not be
activated properly.
Sometimes it's
a broken tab on the switch holder, allowing the switch to rotate just
out of position. This tab
can be hard to see, since it is under the
bottom edge of the switch.
If the switch mount is
broken, it's usually more economical and
safer to add a dab or two of hot glue to the mount to secure the
switch. Let it cool for about 30 minutes before using.
One test that sometimes
helps is to
gently lift up (and/or push down) on the door or handle as you try to
start it. If it works or tries to work, then it's a door switch mount
or
door alignment issue.
You can download many LG service manuals here, but strangely, they do not have part numbers in them.
You can order parts from
Encompass here
or you can call them toll-free at
866-779-5835.
If you don't find your model's service manual or need more help, feel free to contact me directly (and please remind me of your
full model number from the tag on the unit) for more
information & help.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
If you only need a
switch, you can order a universal type here for $5 postpaid.
If you think the problem
is on the control panel, we repair these nationwide by mail
for $39.95 postpaid in most cases in about a week or so with a one-year
guarantee.
We're
happy to help you with free advice and we'd appreciate your thoughtful
William E. Miller
[email protected]
http://www.microwavedisplay.com
SOURCE: Need a copy of manual for LG Intellowave Microwave
I found a copy for my LG microwave on retrevo.com. They list several brands and models. It was free to download and will even save it on their site. You do have to register your email address, and get a password. Mine is printing out as we "speak".
meowpfttpftt
