Sony VPL EX7  LCD projector  2000 ANSI lumens  XGA (1024 x 768)  43  VPLEX7 VPLEX7 Projector Logo
Posted on Jan 02, 2012
Want to reset sony vpl ex7 - Sony VPL EX7 LCD projector 2000 ANSI lumens XGA (1024 x 768) 43 VPLEX7 VPLEX7 Projector
Michal N.
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 27, 2015
Michal N.
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
1550
Points
Where it the RESET located? I do not have any on my VPL-EX7
5 Related Answers
Anonymous
  • 4234 Answers
  • Posted on Apr 09, 2009
SOURCE: Reset Timer Lamp Sony VPL-HS60 projector
According to the manual, you need access to the RESET button, the left and right arrows and the ENTER button to clear the counter. Press the following in order for less than 5 seconds each:
RESET
Left Arror
Right Arrow
ENTER
The above sequence should clear the counter.
Dan
stilyou
  • Posted on Feb 02, 2008
To reset the lamp timer:
1) With the projector plugged in and turned off, press the 'ON/STANDBY' button to put the projector in 'STANDBY' mode. NOTE: You have to press the button on the projector itself, you cannot use the remote for this step (this is not clear in manual).
2) Now, using the remote, press the following keys in order: RESET, <--, -->, ENTER.
3) Timer should now read '0'.
Anonymous
  • 10594 Answers
  • Posted on Jun 01, 2009
SOURCE: how to reset lamp on sony lcd projector xga vpl-px20
After replacing lamp, connect projector AC power cord and turn the projector in standby mode.
Press following keys on control panel for less then 5 seconds each..
RESET, <==, ==>, ENTER.
That will reset lamp timer in projector.
Thanks.
BlackOnyx
BlackOnyx
  • 104 Answers
  • Posted on Feb 06, 2010
SOURCE: LMP-H150 reset hours on sony cineza VPL-HS2
These instructions are for a Sony Cineza VPL HS3, but may be the same for the HS2
1st thing to check - is the cover properly/completely closed - this can stop the projector from working.
Connect the power and set the projector to standby mode.
Press these buttons on the remote control in this order, for less than 5 seconds each.
Reset - Left Arrow - Right Arrow - Enter
This is required, to reset the lamp timer.
Also, something I found interesting from the internet - lamp life isn't when the bulb dies, but when a bulb has lost 10% of its brightness - so you might well be able to reset the timer and get much more use from the bulb - the image just wont be as bright.
Anonymous
  • 30 Answers
  • Posted on Oct 05, 2010
SOURCE: i have problem. LCD projector
pudiera ser que los ventiladores que tiene no esten trabajando por lo que calienta y se proteje debe serrevisado por un experto
How do I connect my PS3 to my sony vpl ex7 projector?
You'll need a down converter similar to this, http://www.amazon.com/PETHV-converter-3-5mm-Stereo-Converter/dp/B003O55U8K
6helpful
2answers
I have sony vpl ex7 and the power button keeps on blinking?
If it blinks with 2 flashes, it's overheated. Check the filter unit.
If it blinks with 4 flashes, a fan is not working properly. see if any fan is not turning on, and check why.
If it blinks with 6 flashes, it's a system internal failure.
I got flikkring picture display with my sony vplex7 projetor
Try a different source ie a laptop and see what happens.This sounds like a source problem.
1helpful
I can't get marry my laptop to the projector the manual is lost. had to buy new usb cord and still can't get the projector to play my video
the projector needs a vga cable or composite connection to show the display from the laptop , it will not work with a usb lead
If you found this info useful please vote for me
vga to vga lead looks like this
a composite lead looks like this
Hello, good day. My problem is relationship my sony xga vpl - ex7 not turn on. Only lighting the lamp/cover.
Either lamp is dead/ broken in projector or lamp cover is not fixed properly (its located at bottom side)
Please check lamp and replace it if its broken and make sure lamp cover is fixed back on its location securely after lamp replacement/ checking.
Thanks.
IC TOP247YN is blasted. from where can I buy it and how to solve the problem
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, and a list of Dealers for spare parts, as required.
When you have purchased a replacement IC de solder the old one and fit the new one.
Just Google the part name and follow the links.
I hope this helps.
1helpful
Sony
Turn on projector and Press following button on remote in following order for less then 5 seconds..
Above procedure is written in user manual page-49
If you need user manual of VPL-HS50, click Sony Support.
Top Sony Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
