Directions for Desk Clock - Without the
C?/F? button To
change the Temperature: Press
the "S" button once (this will change from Fahrenheit to Celsius) To
change the Time and Date: Press
the "M" button once to change time to or from military time Press
the "S" button once to change the hour Press
the "S" button again to change the minute Press
the "S" button again to change the year
Changing the year will also change the day of the week Press
the "S" again to change the month Press
the "S" again to change the date To
set the Alarm: Press
the button with an alarm clock on it Press
the "S" button once
A flashing 12:00 should appear Press
the arrows to set the hour Press
the "S" button again to set the minutes Press
the "S" button again to change the "ring" of the alarm
There will ne a number below the time the alarm is set for
Use the arrows to advance through the options To
turn the alarm functions completely off: Press
the button with the alarm clock on it Press
the "S" button five times
When three dashes appear where the time would be, it is off. Press
the "M" button three times to get back to the main clock function To
clear the secondary clock: You
can set two different times on the clock, so if you travel frequently you can
have a home time with alarm and a travel time with alarm saved and ready to
go. There is a primary time, the one you normally see on the clock with
an alarm clock function after it. There is also a secondary time with an
alarm function after it. Clearing
the secondary clock will make it easier to know when you get back to the
primary clock function. Press
the "M" button three times Press
the "S" button seven times
When three dashes appear where the time would be, it is off Press
the "M" button two more times And
you are Done!
Directions for Desk Clock - Without the To Press To Press Press Press Press Press Press To Press Press Press Press Press To Press Press Press To You Clearing Press Press Press And
C?/F? button
set the Alarm:
the "S" button once
you are Done!
Place your Seth Thomas atomic clock face-down on a table or desk and locate a series of buttons labeled "PST," "MST," "CST" and "EST" on the back of the clock. Press the appropriate button to set the time zone.
Turn your attention to the small lithium battery-powered digital clock display on the back of your clock. With the correct time zone set, the digital display should accurately reflect the current local time.
Locate the AA battery compartment on the back of your clock. Put two new AA batteries into your clock's battery compartment.
Set the "Mode" switch on the back of your Seth Thomas atomic clock to "Run." Wait for it to adjust to the correct time. The automatic time-adjustment process can take up to 45 minutes, but is usually completed much sooner.
