In some situations the picture and the text extend beyond the screen
size. is there something we can do to shrink the picture and make it fit within the screen?
Your tv needs to be put into service mode with the original Sony remote control and then set the vertical\horizontal size parameter to the correct values and then burn the new settings to memory
Google " sony tv service mode " and you should find the procedure. Good Luck! Write back if you have problems.
barneyluc
not sure what half screen you are referring to also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings on the top of the internet page you should see some tabs file edit view favourites tools and help click on the view tab on the drop down list you should see a zoom size % click a different percentage also a text size you might try a different text size although this will not increase the size of the page only the text fonts inside it if you do not see these tabs in the top toolbar right click in the top toolbar you will see a number of toolbars and options select the menu tab this will add at it to the toolbar
click start control panel display desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
always click APPLY after making any changes
or if its actually half of the screen
you will need to connect to another monitor or your television to your computer with the vga lead monitor connection
click start control panel display change display settings adjust resolution this may vary depending on your operating system
you should see a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system
when you select the no 2 tab this should be the extended desktop always click apply after making any changes
or click start control panel administration tools computer management device manager scroll to monitors right click select scan for hardware changes
if you can get an extended desktop your monitor is faulty
if you cant get an exended desktop
hope it helps
