I have a Samsung HL-S6187W, a DAV-HDX275, a PS3, a Cox HD cable receiver, and a Monster HD 3-Way switcher. I was able to get surround sound from the tv, and a picture from the ps3 but no sound. I had the ps3, the cable, routed to the switcher and the switcher to the tv.
Any suggestions on an optimal setup?
Thanks
SOURCE: Codes for DAV-HDX275 BRAVIA
Amigo conseguiste resposta para trocar a regiao do home theather de 1 para 4? No aguardo, [email protected]
SOURCE: problems with hearing sound from bravia LCD tv through bravia DAV-HDX275 theatre system
The fiber optic port on back on your bravia tv is only for when your using a over the air antenna and watching local atsc channels in your local market. You need to run the fiber optic from your hd cablebox if it has one or your hd sat box if it has one. If you don't have a set top box with the fiberoptic port on it you can use a digital coax cable from the cable or sat box to sound system. The only other way to get sound if you don't have a cable or sat box is to run the red and white rca audio cable from the tv to the sound system and got to the audio setup on tv and turn the tv speakers off and you might have to adjust the audio to fixed instead of variable.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
SOURCE: Connect PS3 for playing/viewing blue-ray thru surround sound
I just finished setting up my system last night and was facing similar problems with sound/video from my PS3. The only option I could get working was to have the HDMI cable connected from the PS3 to the TV and then connect the Optical cable to the receiver for sound. I was under the impression that HDMI handles sound and video but for whatever reason the PS3 does not agree.
I have DTS sound and fantastic picture now through my PS3, hope this helps.
Cheers
i just hooked up my sony blue-ray to my samsung suround sound.but i cannot get the sound to work.
SOURCE: Can't get XBOX 360 to have audio through surround sound speaker
Make sure that you have the RC Cables (red and white) plugged into the audio ports that coincides with the component video inputs. If that wont work then try plugging the audio and video cables into the inputs for the satellite, since that works. That way you can isolate the issue. If it still wont work try using the XBOX 360 HDMI cable. That has both audio and video.
