Mp3 player keeps turning off on it's own and the settings keep switching back to factory settings after turned back on. Mp3 player keeps turning off on it's own and the settings keep switching back to factory settings after turned back on.
AnonymousJan 10, 2009
My mp3 player keeps restarting in the middle of songs
Question edited for clarity, full make model (what it is).
Did you follow Section 9 about fully charging the battery, pressing and holding the button?
Charging Instructions 1. Plug the charger into the mains - the charger indicator light will be green.
2. Turn on the battery by press and holding the power button until the green light is illuminated.
3. Plug the battery into the charger. The charger light will turn from green to red to indicate the charging process has started.
4. Once the battery is fully charged, the charger status light will be
this happened to me wen i first got mine, so what in the manual the mp3 will need at 4 hours at first to be charged fully, when u charge it flip the on/off switch ON, n let it sit as long as you can. thats the only way it will charge, the reason why it keeps turning off is becuz its on low battery
Check if it's fully charged. Try connecting to different charging source. Press and hold the Reset button for 30 seconds then try connecting to charging source and try turning it ON. If the player doesn't respond send it for service.
If you let the battery get too low, the battery will not charge because the motherboard does not have enough power to control the charge process. There are two ways to fix this. 1) buy a new battery that will be supplied fully charged. 2) borrow a friends HDD065, fully recharge the battery and remove it. Place the battery in your player and turn it on. Put your player on charge. Without turning your player off or removing the charger, remove your friends battery and place yours in it. It may take a couple of attempts but you should be able replace your battery and keep the player operational. Leave your battery to fully charge.
damn yo...i have the same problem....today all of a suden i turned it on, the green light stays on for about 5 seconds, then it just turns of, and its 80 percent charged!!
some may be due to low battery power or due to software problem...while charging stop once the charge gets full,...dont overcharge the battery,,,,,,the battery life gets reduced
mp3 keeps turning off
my philips mp3 keeps turning on and off till the batterie runs out???
philps go gear
my music player keeps turning off and i turn it on and it says refreshing media and than shuts down
keeps turning off
