How do i copy a phone book for the Uniden DECT1560 cordless phone
Kathy,
This should do the trick!
Copying Phonebook Entries to Another Handset:
You can transfer one phonebook entry at a time or all phonebook entries at once.
1) With the phone in standby, press the address book icon.
2) To copy one entry, find the phonebook entry you want to copy, press Menu /Select , and then select Copy.
To copy all entries, press Menu /Select and then select Copy All.
3) Move the cursor to select the handset which you want to transfer the entries to and then press Menu /Select .
If you select Copy All, Are you sure? appears on the display screen. Move the cursor to select Yes, and then
4) The phonebook entries will be transferred to the designated handset. During the copy process, the receiving handset shows Receiving and the ID of the sending handset.
5) When the transfer is completed, Done! appears on the handset.
Notes: • The handsets must be currently connected to the same base.
• If the handset you want to transfer to already has seventy entries in its phonebook, you will hear a beep and Not enough memory in receiving unit appears on the display.
• If the selected handset is out of range or data transfer is cancelled, Unavailable appears in the display, Phonebook listings will not be transferred.
Have Fun!!
2 of 3 handsets say unavailable
