Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Bissell model by clicking the link below.
Bissell 9400 3 User Manual
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Bissell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
SOURCE: Bissell 9400 ProHeat Upright Upholstery Hose
Set Ready Tools Dial to the Hose
Attachments Setting. This will allow spray and
suction from the hose.
Set Custom Clean Dial for Heavy Traffic, Normal
Clean, Light Clean, or Rinse, as desired
Attach the cleaning tool to the end of the hose.
Plug in and turn on the Power Switch and Heater
(if desired).
Clean by pressing the trigger to spray solution
onto the area to be cleaned. Slowly move the tool
back and forth over the soiled surface. Release
the trigger to suction soiled water. Continue to
clean in the area, working in small sections, until
no more dirt can be removed. Rinse (optional)
and suction as needed.
SOURCE: Bissell 9400-E carpet cleaner
Take this link to bissell and click on Pro heat 2 x select user guide. http://www.bissell.com/Product_Search.aspx?Criteria=9400-E
SOURCE: I need an owners manual for the bissell 9400-s
CLICK HERE for the PDF version of the manual.
Choose English or Spanish
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
SOURCE: need manual for bissel 9400
You can download the instruction manual in PDF format by clicking this link.
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Thanks for using FixYa.
SOURCE: i want instructions manual for bissell model 9400/e
Hello Rowland,
Go to:
http://homeappliance.manualsonline.com/manuals/mfg/bissell/9200_series.html?idRes=1297252
(Be careful to copy ALL of the URL address).
If this is your Vacuum cleaner, then download the manual and print a copy.
It is a free service.
