Tv worked fine yesterday went out lastnight and accidently left the windows up at home.. Came home this morning house was FREEZING as it is cold in January.. Went to turn tv on and NOTHING.. ABSOLUTLY NO POWER.. Unplugged the tv to reset and still nothing..What can I do to fix this?
SOURCE: Power button Flashes
Bad Convergence circuit , replace 2 STK392-110 & fuse will take care the problem
SOURCE: magic focus
If your model has magic focus it should be behind the flip down cover on the front panel next to the auxillary video inputs
SOURCE: HITACHI 55VS69 BLUE SPOT ON SCREEN.........
yes the light engine needs replacement.but also check out the bulb.because many a times both get faulty when light engine has problem.
SOURCE: Hitachi 43FDX20B, watching tv, screen went blank,
The TV computer may have detected an error. See if the problem persist after unplugging the device overnight to reset it. If it does not, the issue may be with the board or its power supply circuit. Probably loose soldering or leaking capacitors.
