Computers & Internet Logo
France Posted on Jan 01, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
NO POWER Suddenly the laptop has stopped powering. I have tried powering without the battery nd it doesnt work. How do I find out if the problem is with the charger or the charing socket in the laptop?
Wale Sarumi KomputerSolution
Level 3:
  • Master 6,993 Answers
  • Posted on Jan 01, 2012
Master
Level 3:
Answers
6993
Questions
Helped
1701142
Points
1261
Hello, use the charger on another laptop and use another charge with your laptop. By so doing, you would now if its a charge fault or not. If its not a charger fault, it means the charging socket or the power board of the laptop is defective. You need to disassemble the laptop to get to the root of the problem. Regards.
I have a good day estimated presario 700 laptop and I need help because they will not start, I connect the power supply and keeps the battery light turned amber, in conjunction with the direct power. no...
unplug the power cable from the laptop
remove the battery then press the power button for 5-10 secs
plug in the power cable to your laptop WITHOUT the BATTERY
try to turn on your computer if still doesnt work try a known good A/C adapter if still doesnt work then mobo needs to be replace
2helpful
Sony viao wont boot, battery light flashes amber once when power button is pressed, AC power indicator on laptop is green and responds to being un-plugged and the adapter LED is green,but it still wont...
Move the power jack around while plugged in, does the blinking on the battery stop when you hold it in certain positions? If so, your dc-jack needs to be soldered, but i probably was loose already before you started using it. It could be a broken motherboard issue as well. You can try to open the laptop and check the dc connection. There is a Laptop Repair Guide that shows you how to take apart a laptop, the sony may be made in a similar way. Sony Repair NYC
2answers
My dell laptop suddenly stopped working without the power cord. power cord needed to be repaired, it had a gash exposing wires. fixed it with electrical tape but it is no longer portable, did i mess the...
It sounds more like the large portability battery has been 'messed' i recommend getting a new power cord. Whist you may have repaired the cabling and it may have appeared to work, the escape circuit for charge may have been broken but it is not required for the laptop to work, but is important when recharging the battery. I recommend getting a new adapter and then if that doesn't work a new large battery also.
2helpful
3answers
2answers
Will not power up, no lights or sound
tried to remove battery and ac for a little while?
if that doesnt work, remove battery and ac-power.
remove the ram
put ac-power back and try to boot without ram
(do you get a beep/error?)
remove the ac again
insert the ram
insert battery
insert ac
try to boot up again.
if that doesnt work its probably a mainboard error and you need to take the computer to repair.
My T42 suddenly wont recharge the battery or wrk off mainsadapter
If the Laptop wont work off the power adepter, it also will not charge. The adepter could be bad (even if showing a power light) or the connector on the laptop could be broken. The best test is to take the battery out, attach the power adepter and try to start the computer if it starts, your battery is at fault. If nothing, suspect eh charger first. Be sure the pin on the Laptop power connector isn't bent or broken.
Aspire 5003WLMI No Power
you have a hardware problem which would require opening your laptop. i suggest you bring it to a computer technician who can do the repair for you to avoid further damage.
Losing Wireless Connectivety, when charging.
Try to plug in the power cable alone, do it without the battery and see if your wireless works.  If your wireless works without the battery, and works with the cable alone it may be a battery conductivity problem.
Toshiba M35X-S109 Doesnt Start
you may have a faulty motherboard connection, but try connecting the power adapter in without the battery and see if it runs, then replace the battery back in the compartment.
Grand Canyon Tech
Grand Canyon Tech
