Lands Phones Logo
brian dowdall Posted on May 09, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a GE 29870GE1A and I get the
I get the "low battery" warning but for the life of me I can't find any "opening slot" that would hold a battery. I have the original manual that shows the "battery compartment door", but the plastic moulding is solid and there is no compartment. Is there a chance that the 29870GE1A doesn't have the battery option??? There are 2 phillpis screws at the bottom of the base, but I am sure that I am not to take the entire back off to get at the battery. Sure would like some help with this. Brian
solver2010
Level 3:
  • Master 923 Answers
  • Posted on May 09, 2017
solver2010
Master
Level 3:
Answers
923
Questions
0
Helped
192884
Points
2907
5 Related Answers
Anonymous
  • 71 Answers
  • Posted on Jan 21, 2009
SOURCE: Wharfedale IN120-1 How do I record my own answering machine message?
Generally, there is "greeting" key on base, hold serveral seconds untill you hear a "beep" , then begin to record.
Or handset have menu, like "answer machine" ,"Record OGM" like that. record OGM from handset.
Anonymous
  • Posted on Jan 15, 2011
SOURCE: Unable to open battery compartment--- GE phone, model 27909
you just push in the button and then slide the back of the phone upwards. but you have to give it a good push to slide it up
Anonymous
  • Posted on Feb 06, 2011
SOURCE: need to open handset for
After taking out the two screws from below the battery compartment, the case will separate slightly on the bottom. Take a screwdriver and carfully pry the case open along both sides, working from the bottom toward the top of the handset. This will free the back of the handset from the primary components. It will simply snap back together when done and then replace the two screws.
casouzaj
CARLOS R SOUZA JR
  • 1118 Answers
  • Posted on Jun 20, 2011
SOURCE: i bought a cordless uniden
Your phone's owner manual can be downloaded from this location.
Hope you are able to sort your problems out soon.
Anyway, please, let me know if I can help you out any further.
Regards, Carlos
Anonymous
  • 3 Answers
  • Posted on Aug 04, 2011
SOURCE: Somehow, our Uniden 6.0 phone
Hold down the pound key (#) until it goes away.
1helpful
tip
Low Power Warning For Full Charged Camera Battieres
<span> <p>I have noticed that, some users asked that, there old cameras always display low power warning for full charged new batteries, or there will be a low power warning after only taking 5-6 pictures.<br /> <p>If you have met this question (I wish not), I'd like to share the solutions.<br /> <p><span> <p>The this problem are so common for <a href="http://www.digital-camera-batteries.net/canon.htm">Canon PowerShot</a> A series cameras when you try to powered your camera by Ni-MH batteries. This is because that, the camera judge the battery is power off by voltage of the battery. And if you use Ni-MH batteries for your camera, the Ni-MH batteries' voltage is lower than the Li-ion ones and close to the camera's judge voltage of low power, so the camera will warn you to change a new battery.<br /> <p>So if you use <a href="http://www.digital-camera-batteries.net">Li-ion camera batteries</a> this questions will be solved simply.<br /> <p>From <a href="http://www.pda-battery.ca/camera-tips/digital-cameras-low-power-warning-for-full-charged-new-batteries/">http://www.pda-battery.ca/camera-tips/digital-cameras-low-power-warning-for-full-charged-new-batteries/</a><br /></span><br /></span>
on Apr 26, 2011 • Cameras
tip
Prolong cellular battery life
Always allow your mobile phone's battery to drain before charging it. Let it warn "battery low" at least three times before you can charge. charging in-between before battery is drained, shortens the battery life gradually.
this is from a personal experience.
on Dec 03, 2009 • Cell Phones
25helpful
Battery warning
Just ran into this problem. New 3rd party battery with the badly translated message:
"Battery Life Time in current state is not longer.
Because you may lose your data during using, please replace to new battery.
(honest goods)
Tip> Battery Pack is Cunsumerable device.
This pack is not working correctly or life time is not longer,
please use to replace to new battery (honest goods)."
What I did was when the message pops up, hot ctrl-ald-del > start task manager > right click on it in applications and click "Go to Process" > right click on the .exe file and "open file location" > and just changed the name of the executable file by just putting a 1 on the end of the name. No more pop-ups
Who the hell uses Easy Display Manager anyway? Stupid program.
1995 mighty max dashboard warning lights
Maintenance required light could mean its time for an oil change. Do you have a check engine light too ?
The battery/brake light can mean the brake fluid is low or the battery is not being charged by the alternator.
I just bought a 2000 Ford Mustang GT convertible and when I started it up this morning, it had the warning light thats yellow with an "x" in it....it has a brand new battery from the dealer and...
The only symbol on the dash that resembles an X is the low coolant warning light, if so the coolant may be low or the connector may have come loose, it's located on the holding tank on the drivers side of the radiatior.
The initial battery of my Acer Travelmate 2480 packed up and I ordered and installed a new one. However, the laptop remains on "AC Only" power and the battery is not charged, giving a...
RTFM You can download the manual by googling "acer travelmate 2480 manual" (without the quotes). Or just click here
According to the Acer manual:
"Conditioning a new battery pack
Before you use a battery pack for the first time, there is a
"conditioning" process that you should follow:
1 Insert the new battery without turning the computer on.
2 Connect the AC adapter and fully charge the battery.
3 Disconnect the AC adapter.
4 Turn on the computer and operate using battery power.
5 Fully deplete the battery until the battery-low warning appears.
6 Reconnect the AC adapter and fully charge the battery again.
Follow these steps again until the battery has been charged and
discharged three times.
Use this conditioning process for all new batteries, or if a battery hasn't
been used for a long time. If the computer is to be stored for more
than two weeks, you are advised to remove the battery pack from the
unit.
Warning: Do not expose battery packs to temperatures below 0°C
(32°F) or above 60°C (140°F). Extreme temperatures may adversely
affect the battery pack.
By following the battery conditioning process you condition your
battery to accept the maximum possible charge. Failure to follow this
procedure will prevent you from obtaining the maximum battery
charge, and will also shorten the effective lifespan of the battery.
In addition, the useful lifespan of the battery is adversely affected by
the following usage patterns:
• Using the computer on constant AC power with the battery
inserted. If you want to use constant AC power, you are advised to
remove the battery pack after it is fully charged.
• Not discharging and recharging the battery to its extremes, as
described above.
• Frequent use; the more you use the battery, the faster it will reach
the end of its effective life. A standard computer battery has a life
span of about 500 charges."
2helpful
2answers
GE Simon 3 low battery warning: Newer battery has 6.54V?
Read the battery voltage with the system on but with the ac power disconnected. I always suspect the battery from experience. Battery needs to be replaced every few years normally(but can vary).
Top GE Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
