Question about Tomtom XL 330 Car GPS Receiver
I have tomtom go 720..(only had for about 4 weeks) it was working fine ,then i took it on flight from texas to Ca. it worked there but upon returning to texas 5 days later, it will not work..i thought charging it would solve it but all i get is the screen to come on..then it will not do or let me do anything by touching screen...after 10 minutes or so an X appears then still until the red X starts flashing i can't even turn off...i can not use this at all ..i tried reset button....i'm sure i have failed to do something silly but i can not figure this out....thanks, monica
  • 4 more comments
  • monica74202 Oct 05, 2008
    also there is not a memory card in the slot and there is a icon at bottom right of a small rectangle with a circle inside maybe like a disc...was there a card there and i lost it ??
    ok i can't find anywhere in the owners manual on how to remove battery..how do i remove battery ?
    i just re-read contents of my box it said sd card not included...it is for additional maps..what about how to remove battery...
    what about the battery
    what to do
  • monica74202 Oct 06, 2008
    sweet rascal obviously i am looking for an answer and am trying everything suggested...nothing is working
    Genius:
  • 1,550 Answers
Go for update it will solve your problem.
Try this and post back if your problem still persists .
Posted on Oct 05, 2008
  • 2 more comments
  • Anonymous Oct 05, 2008
    1. Audio out connector
    2. TomTom Connector
    3. Reset button
    4. USB connector
    5. Memory card slot
    I got this picture from the below source
    sourcehttp://www.gpsmagazine.com/2007/09/tomto...
    After removing the screws, remove upper card, by 2 screw this give you access, to see the battery but you CANNOT remove it from where you see it.
    The only way is to prior the back on the screen up and out, this will give you access to the battery.
    Also DO NOT disconnect the ribbon cables as you will stuff up the connections and they are plastic and will break if touch, there is a special tape on them to stop you removing them.
    One tricky bit is to make sure when you remove metal bracket for the Tomtom release( bracket that seat on top of battery) to note which way you removed it, as it has to be relocate back on a pin within the unit housing.
    This is the push button mechanism that you push to release the Tomtom for the window device.
    You will need to remove the industrial type tape on both side of this bracket which is tape to the battery itself, before you can remove the battery via the screen area.
    One more NOTE: The screen is probably the hard's thing to remove, just prior the outer edge real slow and easy with a screwdriver, the outer retainer need to move FIRST then the screen itself, watch out for the ribbon cable and circuit board at the rear of the screen, can be damage if you put the screwdriver to far under.
    So better get assistance from professional people for removing the battery
    The source for above instruction
    sourcehttp://www.mtekk.com.au/Forums/tabid/56/...
  • Anonymous Oct 06, 2008
    If your gps in under warranty take to the store and fix your problem under warranty .
    Its very difficult to rectify your problem without technican help .
    Genius:
  • 1,011 Answers
Dear,
This solution can be used in the following situations:
• The device hangs in the start screen (splash screen)
• An SD-card with a red cross is displayed on the screen
• A picture with a red dot and white cross is displayed
• The device can’t be turned off
If you haven't already done so, please download and Install TomTom Home fromhttp://www.tomtom.com/7602
If you don’t have a full backup of your TomTom yet we advise you to make one before continuing with the steps in this email. You can make a backup by following the steps below:
1. Reset your TomTom device: http://www.tomtom.com/6965 and connect it to your computer.
2. Click on 'Backup and Restore -> Backup' in TomTom Home 2.0
3. Enter a name for the backup and click [OK]
• IMPORTANT: When the software is asking to delete parts from the backup click [NO]
After the backup is made you delete the files from the root directory of the TomTom. Follow the steps below to do this:
2. Open My Computer in Windows, or Finder in Macintosh from your desktop and turn on your TomTom device.
3. On your screen a new removable disk appears, this is your TomTom device, click on the disk to open it.
4. You will see a list of folders and a list of loose files
5. Delete all of the loose files. IMPORTANT: The folders with their content must NOT be deleted.
5. Close the window when all files are deleted by clicking on the [x].
Next we will reinstall the application via TomTom HOME.
1. Start TomTom HOME on your computer
• TomTom Home should automatically check for updates and prompt you to install them, if not:-
2. Click on 'Update my device'. If you get the message 'No Items Available', or there is not an application to download, click on 'Add Maps, Traffic, Voices etc -> Items on my computer', select the application and click on 'Add'.
3. Select the Application update.
4. Click on 'Device -> Disconnect Device', then turn off your device when it is done installing and disconnect it from your computer.
5. On a PC, in the System Tray by the computer clock, click on the 'Safely Remove Hardware' icon and disconnect the TomTom also in this way.
When switching on the device it should boot as normal again.
regards,
rate it only if it help or fix it!
Posted on Oct 06, 2008
Several easy steps would solve the problem:
1. Make sure you have TomTom Home installed on your computer. If not, go to http://download.tomtom.com/sweet/application/home2latest/TomTomHOME2winlatest.exe
2. Hit the RESET for about 15 to 20 seconds on your GO720
3. Connect your GO720 to PC via USB cradle/cable
4. Hold the POWER button for 10 seconds or until you see a black and white boot screen, then release the POWER
5. Hit the POWER again, the GO720 will restart and connect to PC
6. RUN TomTom Home and the program will recognize your GO720 and install new navcore application.
Posted on Apr 04, 2009
    Scholar:
  • 116 Answers
If your device shows a flashing 'X' after you turn it on, the TomTom application is not installed or cannot be found.
To solve this, reinstall the application. Follow the steps below.
Tip: Data transfer may not work properly if the connection to your computer is via a USB hub or keyboard.
  1. Reset your device.
  2. Connect your device to your computer.
  3. Turn on your device by pressing the power button for 5 seconds.
    TomTom HOME starts.
  4. In TomTom HOME, click Add Maps, Traffic, Voices etc. and then click Items on my computer.
    Then expand Applications by clicking the plus symbol i have tomtom go 720..(only - homeplus.jpg and click Add.
  5. Note: The application is only available at this location if you previously updated it via HOME. If you never updated the application before, click here.
    If you never updated your device on this computer, click Update my device.
    Important:
    If HOME asks you to Unplug your TomTom device, try clicking OK first.
    If HOME notes that a problem has occurred, click Back.
    HOME offers to download and install the latest version of the TomTom application.
  6. Click Done.
  7. In HOME, click Device > Disconnect Device.
    Your device should now start up again. If it hasn't started up after 10 seconds, press the On/off button
First, attempt the following: TomTom device frozen or looping.
Lastly, if your device still only shows an 'X' after you turn it on, try formatting the internal memory or memory card of your device.
Click here to learn how.
    President:
  • 1,952 Answers
battery can be removed by the following text
NOTE:
on how to remove the battery, after removing the screws, remove upper card, by 2 screw this give you access, to see the battery but you CANNOT remove it from where you see it.
thanks for using fixya
rate my solution
  • mohammed marika thambi
    mohammed marika thambi Oct 05, 2008
    its an Lithium Ion batteries: If they get too hot, they explode.
    So if you have to do any soldering, make sure that you use heatsinks
    between the heat and the battery and you work quickly. If you are a
    beginner at soldering, don't practice with a Li-ion battery!
    President:
  • 2,712 Answers
You will probably need to have the firmware flashed or updated. However, the good news is that your GPS is still under warranty. So in my honest opinion, the best thing to do would be to take it back to the store where you purchased it and ask them to fix it for you under warranty. Don't try to attempt anything yourself and screw up the device further and void your warranty.
Hope that helps!
Cheers!
IrishDruid
  • 1 more comment
  • Swilin Sampson
    Swilin Sampson Oct 05, 2008
    Please refer to the following articles from Tom Tom website as well:
    I think the reason you are having this problem is that you perhaps had an SD with the software, and it is missing now. However, I could be wrong. Please do read the articles above, and if you still have an issue, then take it back to the store.
    Hope that helps! Should you have any further questions,
    please post them here.
    If you are satisfied with my solution or have no further queries, please take a
    moment to "Accept" this solution.
    Thank you for using Fixya!
    Cheers!
    IrishDruid
  • Swilin Sampson
    There is no battery. Please follow the instructions here:
    Device shows flashing 'x' when turned on
  • Swilin Sampson
    Swilin Sampson Oct 06, 2008
    Have you tried reinstalling the HOME software on your PC? And did you follow the instructions given here:
    Device shows flashing 'x' when turned on?
    If you've done evrything and it still does not work, take it back to the store and get it serviced/replaced under warranty. Dont try to open the device to replace the internal battery, or your warranty will be voided.
    Brigadier General:
  • 3,614 Answers
First try to remove the battery for 4 hours, this procedure will reset and restore the previous and default settings of the unit..
let me(*us) know here again...
  • micromaster
    micromaster Oct 05, 2008
    IT WAS A INTERNAL BATTERY, AND ITS NOT ADVISABLE TO OPEN THE DEVICE COVER TO ACCESS THAT PART. IT SHOULD BE DONE BY AN AUTHORIZED SERVICE TECH FROM TOM2X.
    BUT IN THE MOMENT THAT YOU HAVE THIS PROBLEM TRY TO FOLLOW THIS FEW STEPS:
      TomTom HOME starts.
      Then expand Applications by clicking the plus symbol, and click Add.
      Note: The
    5. Click Done.
    6. In HOME, click Device > Disconnect Device.
    7. Your device should now start up again. If it hasn't started up after 10 seconds, press the On/off button.
    Genius:
  • 3,422 Answers
Hi.
First do a hard reset again.Then connect your tomtom to the computer and run an update.
This will solve your problem.Let me know the result.
  • 6,487 Answers
First thing to do here is to remove the battery from the unit for about a minute to refresh the device , then after 5 minutes put it back in then try to charge it and also check if the red X is still there if not check if the screen will now come on...
Hope that helps........
  • Mark Gil
    Mark Gil Oct 05, 2008
    You need to have a memory card for this on and that can be the reason why you have this problem now, so better try putting first a memory card on this unit and check if the problem will be resolve...
    Guru:
  • 1,894 Answers
Try to do a factory reset and then try to upgrade your firmware.
this will solve the problem easily
  • 1 more comment
  • dewan nafees ahmed Oct 05, 2008
    this is a firmware problem sir.
    HOW COULD THE memory card simply jump put of the unit without your knowledge??
    please update the firmware and get the problem solved
  • dewan nafees ahmed Oct 06, 2008
    did you flash the firmware or not?
    i said you to update the firmware right?
    please do it
  • 1,879 Answers
Your model needs the SD card
SOURCE:
720 GPS screen off center
This is just a guess, but when you reconnected the flat ribbon cable cable to the board, you might have somehow not gotten it centered in the connector.
Jan 14, 2010 | Tomtom GO 720 GPS Receiver
Tomtom 720 will not turn on even after pressing reset button
hook it to your usb cable to your for a few hours and then try and start it. first with the power button, it that fails try the hard reset..if neither those work, download tomtom home. follow the directions and tomtom home should be able to repair it unless you have internal problems, like a bad usb port on the gps. bill
Aug 18, 2009 | Tomtom GO 720 GPS Receiver
Tomtom speaker stoped working
More than likely the small spaker inside has siezed up!
You can puchase a replacement (search ebay for replacement speaker tomtom) for about 10GBP.
They are easy to replace - 4 screws on back of 710, pop out main unit, and remove 4 screws holding speaker, unplug and install new one - reverse to assembly once more.
I had a strange experience in Vegas when I took my tomtom710 on vacation. the tomtom was silent in the UK - speaker dead as a doedoe, however 3-4 hours in the Vegas heat on the dash made the speaker pop back into life!
Result I thought, however on return to the UK the temp had returned to below miserable and the tomtom didn't wanna play ball anymore.
So, tested the output internally with another temp speaker, all works fine - so just ordered a replacement "original" tom tom speaker to fully fix.
Jun 02, 2009 | Tomtom GO 720 GPS Receiver
Adhesive on screen
Rubbing alcohol or a soapy water solution using a soft cloth or paper towel would work fine without scratching your screen
Dec 09, 2008 | Tomtom GO 720 GPS Receiver
Tomtom 520 driver not installed,not syncing with laptop
what you need to do,
hold the reset button for 20 seconds which is located at the bottem of the tomtom (make sure to use a pin or similar in size).
then connect the tomtom to the computer and turn it on.
this should reconnect and allow you tomtom to communicate with the computer
Dec 02, 2008 | Tomtom GO 720 GPS Receiver
Tomtom stuttering
TomTom Home now has a fix which corrects the stuttering problems with the computer voice needed for the 'text to speech' function on the GO720. Simply plug your device into your computer and have it connect with your computer. You should automatically see a large fix available which will correct the problem. Download it as I did, and the problem is corrected.
Nov 30, 2008 | Tomtom GO 720 GPS Receiver
TomTom go 720
If you have two devices you must have two email address. One for each device. This is the way tt home works. Another way to get around it is to open tt home preferances and in general preferances make sure remember my password is not checked. Sometimes a popup will want you to log in just click not this time at the bottom left cornor and then tt home will go on and update your device without loging in.
Hope this helps
Oct 29, 2008 | Tomtom GO 720 GPS Receiver
Downloading Free Maps for TomTom GO 720
I want dowloading free maps for tom tom go 720
Apr 02, 2008 | Tomtom GO 720 GPS Receiver
Tomtom XL 330 Car GPS Receiver Logo
3,733 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
