Am I able to remove the roof of the oven or do I have to lie upside down to clean it. Can I use an oven cleaner on it? I have inherited it and the previous owner has never cleaned it! thanks.
I have been using the Lakeland brush on oven cleaner for ALL of the inside of the oven including the stay clean bits without any problems. With the 720, I just brush on the cleaner and follow the instructions. To answer you question, I don't actually lie upside down, you should be able to reach it fairly easily. You may need a number of attempts to get the worse of! Be careful of the thermostat sensor at the top rear right of the oven. It should be bright and clean but will not take any heavy handed cleaning, especially the thin wire leading to/from it. FYI the fan cover at the rear of the oven is held on by 4 self tapping screw and comes off/ goes back on with any problems.(The rear of the cover by the vents build up with grease). Don't use the cleaner on any aluminuim bits ( which includes the fan) as it harms it.
SOURCE: I need an instruction manual for 720EF
Supply me an email address and I will give it the access to my BT Digital Vault so that you can down load the copy I scanned in.
SOURCE: I have a stoves 720EF Heritage - electric - the
No, there is no reset button. However, the grill will only work when the front is down as there is a microswitch which operates to provide connectivity when it is in this position. This is to stop the grill overheating. The switch could have gone faulty.
Does the top oven work ok?
When you operate the grill there are two options, part or full. Are they both failing? Does the cooling fan switch on when either grill is operated?
SOURCE: I need an instruction manual for a stoves heritage 720EF oven
Access details via email on its way to you shortly.
SOURCE: manual for stoves 720ef double oven
Supply an email address on this post and I will give you access to my BT Digital Vault for you to take a copy.
SOURCE: Stoves 720EF - main fan not working
When you say the main fan, do you mean the background cooling fan or do you mean the circulating fan in the bottom oven?
Do you have the handbook for this oven as the wiring diagrams are included in it. If you haven't, you can take a copy from my BT Digital Vault - all I need is an email address to register you.
Looking at the diagram, the power for the cooling fan comes via the timer board. If, as you say, the fan doesn't work at all, the timer board could have gone faulty.
