Question about Nikon D40 Digital Camera with G-II 18-55mm Lens
Nikon D40 green light flashing even when off
I dropped my Nikon D40 from a short distance but onto cement. Now it is not working at all. The lower right side green light keeps flashing even tho it is OFF. I have replaced battery, memory card, tried resetting. Nothing works. Nothing appears broken or is rattling inside. Is it hopeless...
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Scholar:
  • Nikon Expert
  • 156 Answers
Sorry to hear this. Dropping something on concrete creates a high G force. Can you make sure the battery is fully charged before you put it in. If you have a good battery and all it does is blink something must have been broken. I think a D40 is a rather old camera too. Sorry I do not think I can help you. In most times a LED green blinking means it is charging. When carrying a camera you should wrap the strap around your wrist. If you do it correctly if you drop your camera it will not hit the ground. It is best to keep it from dropping on the ground.
Posted on Feb 07, 2018
SOURCE:
  • 435 Answers
SOURCE: Nikon D40 help?!
I assume the lens had the impact. The 18-55 lens has the built-in motors for auto-focus.
Try switching to manual focus (on the lens). If this works, the lens may not auto-focus anymore.
Try it and let me know.
cheers,
Posted on Sep 21, 2008
  • 18 Answers
SOURCE: My D40X won't turn on!
It is required to solder a main pcb.
Posted on May 13, 2009
  • 10 Answers
SOURCE: Dead Nikon D50 in mint condition...
have you tried leveing it on with the battery in for a while
Posted on May 28, 2009
zohail
  • 1223 Answers
SOURCE: Color inaccuracy in D40
CCD going BAD
Call Nikon they will do it FREE it is a known problem now a days kindly call then and get it fixed
RATE ME WELL !
Regards
Zohail
Posted on Jun 01, 2009
  • 6 Answers
SOURCE: Same Problem
Send it to Nikon.
Posted on Jun 26, 2009
How slove the problem
Introduction
Specifications Recommendations
The Nikon D60 is an inexpensive 10 MP DSLR that comes with an excellent 18-55mm VR lens for about $650 as of June 2008. It was a announced in January, 2008, and sold for about $750 with lens in February 2008.
The Nikon D60 is a replacement for the almost identical D40x.
Personally I prefer Nikon's least expensive D40 over the D60 or D40x. The D60, D40x and D40 are actually exactly the same cameras, differering only slightly in their internal electronics, but differing greatly in their prices.
The D60 is actually a D40 body with a few more card-clogging pixels, a VR lens and adaptive dynamic range, but a slower maximum shutter speed with flash.
The D60 is less sensitive to light then the D40 (its default ISO is only ISO 100 compared to the D40's default ISO of 200). Its less sensitive to light because the pixels have to be made smaller to cram more of them into the same-sized sensor. Smaller pixels collect fewer photons than larger pixels. Since the D60 is half as light sensitive, the D60 has to use twice as long a shutter speed or a larger aperture, which makes it more likely to make a blurry picture than the D40. OOPS!
Save your money and get the D40 instead. The D40's faster sync speed is invaluable for use with flash outdoors, and the extra light sensitivity in normal use will help make sharper pictures. These three cameras (D40, D40x, D60) otherwise, for most users, are identical. Compare them in person and you'll see. Megapixels don't matter.
(I detail the few fine points which are new in the D60 further below.)
I had my hands on a D60 back in January 2008. The D60 is an excellent camera, but for most of the people who will buy it, it's the same thing as the $300 less expensive D40. I'd suggest getting a D40 and putting the $300 towards more lenses and/or a bouncable flash.
In fact, the faster flash sync speed (the fastest shutter speed with flash) is more than twice as fast in the D40 (1/500 vs. 1/200), and along with the faster base ISO, the D40 is more likely to make sharper photos for most people, for hundreds of dollars less!
The only significant feature in the D60 over the D40x and D40 is adaptive dynamic range. The D60 does not have any of the other next-generation functionality of the D3 and D300.
The D60 is just a D40 with more pixels, but slower shutter speeds with flash outdoors and less basic light sensitivity due to the smaller pixels needed to jam more of them onto the same-sized sensor.
I make excellent 12 x 18" (30 x 50 cm) prints from my 6 MP D40; do you plan to print bigger? Really? The resolution makes no difference unless I'm printing at 20 x 30" (60 x 80 cm) or more.
Since the D60 costs $300 more than the D40, I'd much rather have a D40, 1/500 flash sync for better daylight fill-flash range, a minimum ISO of 200 and $300 left over to buy lenses and an external flash that I can bounce for better lighting. For instance, the D40, 55-200mm VR and SB-400 is a far better way to spend the same $750.
Sep 19, 2011 | Nikon D60 Digital Camera
Fmay nikon d40 flash in not working..
You might be shooting with a higher ISO or in settings where the D40 meter finds enough light and doesn't activate the flash.
Try changing the ISO to a lower one, like ISO 200 and take some test shots indoors, in a darkened room.
OR, you might have the mode dial set to "no flash". That's the crossed out lighting-bolt symbol. Just set it for P or another mode and you're back in business.
Hope this helps
Mar 02, 2011 | Nikon D40 Digital Camera
When i zoom in to a close range the view is blurred
try to focus on a longer distance. probably you try to focus in a very short distance, and it's below the lens ability.
Nov 02, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
My 55-200 automatic lens will not auto focus on the lower focal lengths, but will on the longer ones. It hasn't been dropped or mishandled and the standard lens works fine. Nikon D40
From the sounds of things it sounds like a part is worn in the lense, my advise is to contact Nikon and send away to be repaired, they have a great service department. I have used them and they are quite inexpensive to.
Oct 29, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
CCD going BAD
RATE ME WELL !
Regards
Zohail
Jun 01, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon CoolPix S5. Red flashing hand. Camera/Lens on/open.
If the shutter is stucked there is no external way to release it Have to show it at camera shop
Mar 15, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D40 help?!
cheers,
Sep 01, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
I think my flash is too bright?
Make sure that the exposure compensation is at zero. If that does not work, make sure that the flash is on automatic brightness. Check the manual if you do not know how to do either one of these.
Apr 11, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
My Nikon d40 build in flash not working after fall
I have also had the problem of flash not working on my Nikon D40. I found out the problem and I made a quick video to help those who are having this problem. Here's the link to the video: Hope this helps !
Nikon Flash Fix
Oct 04, 2007 | Nikon D40x Digital Camera
Nikon D40 Digital Camera with G-II 18-55mm Lens Logo
208 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
