When I press the power button on the remote, the TV light turns green and then immediately goes to a flashing red light. I have also tried using the master switch on the TV (a solution that has worked in the past) and it still comes back to a flashing red light. We have had no power issues. Was watching regular TV last night and just turned off by the remote after I went to bed.
Step 1: Turn on your device. Press the GREEN SET button. While holding the GREEN SET button, press the device button you want to program. Release both buttons.
Step 2: Press the GREEN SET button again. The red light should start flashing.
Step 3: Start pressing the power button until your device turns off.
Step 4: Press the device button again.
Step 5: Enjoy!
MANUAL PROGRAM CODE SEARCH YOUR XR11 REMOTE TO YOUR TV: 1 – Turn ON the TV you will be using with the XR11 remote. 2 – PRESS AND HOLD the SETUP button (bottom left) on your XR11 remote until the LED status light (top of remote) flashes from Green to Red. 3 – Begin manual TV code search by entering 991 on the XR11 remote. 4 – The LED status light will flash Green 2 times. 5 – Repeatedly press the CHANNEL UP button on the XR11 remote to search through the TV codes. 6 – Keep pressing CHANNEL UP button on the XR11 remote until the TV you are programming turns OFF. 7 – After your TV turns OFF press SETUP. 8 – The LED status light on your remote should flash Green 2 times. 9 – Press the TV Power button on the XR11 remote and if the TV turns ON, your XR11 remote is programmed. Be sure to hold the SETUP button until it flashes Green 2 times after your TV turns OFF.
? 8:35
https://www.youtube.com/watch?v=iHBIiRxhe0w
Sep 26, 2014 - Uploaded by ShopJimmy.com
Panasonic Plasma 14 Blink Code Explained with Repair Info How to ... I guess I'll try the SC board and if that does not work simply save up for a new ... The red power led was flashing 12 timespause a few seconds then flash 12 again. ... It powers up and shows the green power light is on, but there's no ...
Oct 24, 2015 - More about : power light flashing wont turn ... December 20, 2013 10:12:55 AM ... sound like it is coming on then it shuts off and the red power light flashes slowly. ... 50in Plasma tv power light is flashing 8 times and won't turn on. ...tv to come on bcause the power button keep blinking my tv will not come on.
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Hi, Flashing red light in Sony tv indicates that tv got some internal problem and went on protection mode to avoid further damage. Now it needs service/ repair. Blinking red light also has an error code that has info about possible cause of problem, let me know how many times red light is blinking after 3 seconds ling pause and model number of your tv to provide you helpful info. Thanks.
Would be great to know the Make and the Model # and if its still under warranty as I strongly believe you are having an issue with the main power supply. Blessings always, A/V Media Tech guy
First, unplug power cable from the back of your TV. You will notice the flashing light is still flashing. Don't worry, go to the Second step.
Second, keep pressing on the POWER button, located on the panel at the top of your TV, to shut off your TV. This will stop the flashing light from appearing.
Third, Plug the power cable back onto your TV
Fourth, press the POWER botton ONCE, using the same button used in the Second step to turn your TV back on.
Fifth, you will see the POWER light comes on, as normal.
Sixth, using your remote control, press the green button to turn on. Your TV should work as normal.
same problem. TV turns on but no picture or sound. when i press power button on the remote control orange light flashes for about a minute and goes back to red.
TV won't turn on. It iz frustating me a lot ay !
