I have the above receiver but not the original manual. It turns on but I am getting no sound from my speakers. On the display, there is a red speaker icon with a slash through it, indicating no sound. How do i fix this problem??? I don't see anything on the remote or receiver, where you can fix this???? Thanks, Phil
SOURCE: rear speakers not working on STR-K740P
The only way your surround sound will work is if you have either the coaxial or fiber optic digital hookups attached to a PS3/Blueray/DVD/Cable box/Satellite box that have digital sound outputs. If you are just using the 1970's version of the red/white audio cables that is stero only.
SOURCE: Zone 2 on Onkyo TX SR805 inoperable
HI pull down the flap on your amp and you will see buttons for zone 2 settings,press zone2 then level up this should work.
hope this helps .
CABLE GUY.
SOURCE: klh r7000 no sound
Like I wrote, I had a similar problem with popping and then no audio for an extended period of time. I found the solution on another site, http://dexsoft.com/blog/?p=15
Apparently the solder joints are weak, and just as the blog described when I opened up the receiver I saw the same scorch marks from overheating. Just as the blog described, I added solder to each of the joints in the photo and have had no problem ever since.
I am no solder expert, this is my 2nd time, but all I did is build up each of the joints and I have been listening to music, playing movies in surround sound with no problems, no popping for the last 2 weeks.
SOURCE: Can get either 1 or 2 speakers working at the same time.
JimRod80,
You say you change theaters which is different than what I propose. Have you tried the "SURR MODE" button on the front or on the remote? the only mode I use is prologic. it has all speakers in surround and doesn't sound like you are in a cave.
