Need bulb with plug in cable attached. part #h3-6v55w
SOURCE: area light works but not the spotlight
Check the contacts going to the batteries. The negative contact is
going the flashlight body. While the other starts at the center of the
bulb socket that goes to the switch and finally to the positive terminal
of the battery. Get it done and send an e-mail .
SOURCE: Need replacement battery for spotlight
You can purchase a battery from Black and Decker, they purchased Vectorlite in 2006, here is the link, you will need to enter the model #
http://www.dewaltservicenet.com/servicenet_home.aspx?AspxAutoDetectCookieSupport=1
SOURCE: looking for replacement parts for vector spot light
The bulb you are looking for to fit these vector spot lights is an automotive bulb, and H3 with a PK22s base. They come with a cable and a nickle size disk at the base of the bulb. They come in several wattages, eg 55w and 100w. Try the "bulbs.com" website, in their search box type "H3 PK22s" and you will see they have a variety of wattages and voltages. Be sure you buy a 12V for these spot lights. They come with a cable and nickle size disk at the base of the bulb. Hope this helps. From Uncle Ray
SOURCE: Vector 2M Pwr Spotlight replacement bulb
It takes a H3 bulb which is available at most parts stores and Wal*Mart stores in the automotive section.
SOURCE: I need a replacement bulb for a Vector VEC139BW 3
I just bought 3 from "The Bulb Man" 2207 Elmwood Ave. Buffalo, N.Y. 14216 (716) 875-2852. He had to order, they came in in about a week. They work fine but bulb has no blue tint, I'm starting to look for the area light when I found this. Bulb, base & wire is all one piece. I think I paid $12-14 for all three a few weeks ago. (Aug 2010)
bulb is #h-6v55w for this spotlight. have been told i could get it at an auto store ? will try. thanks uncle ray.
