It is a little Drill with lots of attachments for sanding, cutting, very small craft projects. I cannot figure out how to attach the bits. ( or perhaps one is stuck- i need to see what stays on, and what i need to try to force off
The multi tool has no "chuck", it uses collets to fix the bits to the tool. Once the knurled cap is loosened or removed, the collet and bit can be removed. If the cap has been overtightened or left in the tool for an extended time, you can remove it by gripping the shank with pliers or vise grip and turn it to release the collet and bit.
SOURCE: HOW DO YOU ATTACH A DRILL BIT TO THIS TOOL? i can
it is not a drill, it is a driver. Unless you change the chuck or add one onto it,. sorry to say., it ain't happennin...
Best regards
Ck
SOURCE: inserting new drill bit
Assuming that it is this drill:
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/blackdecker/7144-04_TYPE_4
You will need a chuck key - hopefully you have that with the drill. It's a little t-shaped bar with a cog on one end. You put it into the holes in the chuck (the part at the end which grps the bit) and turn anti-clockwise to open the jaws. Place a bit in the centre and then turn it clockwise to tighten. Tighten the bit using each of the three holes in the chuck and make sure you remove the chuck key before you use the drill - keep it safe!
SOURCE: I HAVE THIS TOOL, A RYOBI MULTITOOL
Most likely the Dremel attachments will not fit the Ryobi. I know that the Bosch verson of the same tool is different than Dremel. The Attachments are held to the driver with one screw and is located by a series of teeth and slots. There is nothing to open on the multitool the attachment is just bolted on.
I can get off the "ChucK" that has a hand tightened area, but there is still a skinny"bit that is still in there, and i cannot figure out how to attach other things
