If you machine is connected to the network you can scan to smb, is the most used type.first: create folder on your computer, share it, and give it security permission.second open your browser and type the ip address of the machine.
The machine browser will open, look under basic, then on your left side, look under address book, add contacts.
In the contacts you need to add the person name first, then look under smb space only and fill it.hostname: is the computer ip address where you scanning toopath: is the folder name. should be typed exactly the same wayusername: is your computer usernamepassword: is your computer password.
Fill all this and hit submit, go to the machine, select scan to smb, then choose from the address book your name, select it and hit start, it should work. let me know if you got any errors
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Testimonial: "thank you very much,,if you need help with any konicaminolta copiers please let me know,,thanks.."
SOURCE: how to install toner kyocera 4035
open the front cover. lift up the blue lever and pull out the black container. replace with a new one. pull the colorless container for the waste and replace with a new one.
SOURCE: i have a problem with
Open the front cover. Lift the blue lever and pull out the black toner container
HOW TO SET UP SCAN FUNCTION ON A KYOCERA 4035,,ANY TYPE OF SCANING,SMB,FTP , E-MAIL..OR MAIL BOX, THANKS
