Power the v.reader (pink) on, automatically enters touchscreen calibration mode, i touch the crosshair to calibrate, which appears successful, but nothing happens
Hello I buy my son the V.reader for christmas the next day it say Touchscreen Calibration Utiliy, Touch crosshair to calibrate I need help
Not open display display seen touch crosshair to calibrate
This problem occurs when the Storio device needs to be updated with the Storio Recovery Card.
Please follow these steps:
- Insert a SD-card (with at least 64 MB) in your computer
- Go to the VTECH website www.vtech.com
- Select your country/region + Electronic Learning Toys
- Go to 'Service & Information'
- Go to 'Downloads'
- Download the 'Restore Storio Map-maker' to your computer (not to the SD-card)
- When the .exe file is saved on your computer, open it, and follow the step-by-step instructions for recovering your Storio
This should solve your problem. If not, you can contact the VTECH customer service:
- Go to 'Contact'
To find the vreader recovery software, go here:http://www.vtechkids.com/download/us/en/...
What does touch screen colibration means on a vtech stoiro
SOURCE: Ik krijg een zwart beeld met touchscreen
Even bellen met de klantenservice van VTech (www.vtechnl.com) dan krijg je een SD-kaart toegestuurd en met die kaart kun je de Storio resetten en updaten. Het heeft namelijk te maken, werd mij verteld, met een update die ik niet heb uitgevoerd. Daarna zou het niet meer voor mogen komen.
https://vtech.box.com/s/68ee102d30c31a7c5a4d
If your Storio displays a blank blue screen upon start up,
please perform the below procedure to restore the Storio back to factory
standard - please note this procedure requires the use of a blank SD memory
card and some form of SD card reader (either a port on the PC or a USB SD
reader)
•Please firstly download the SD Card Recovery Creator
•Insert your SD card into the SD reader port on your PC or
via a USB SD card reader - this should appear as a removable disk under your
computer menu
•Double click the
Vtech Icon located in your downloads folder to run the program - Click Continue
•Click 'Make Recover
Program Card' then click 'Next'
•From the drop down
menu, select the removable disk drive allocated to the SD card (drive E shown for demonstration purposes,
the actual drive allocated to your SD card may differ)
•The application will
now format the SD card with the Storio factory default operating system
•When the following
screen appears, remove the SD card and then re insert it into the SD port or
reader to complete the format
•Once the format is
complete the following confirmation will appear - please click OK and follow
steps 1-5 to finish restoring your Storio to factory standard.
•Please note, once
the process is complete, you will need to re run the program to 'revert' the SD
card back to a usable state
hi just wondering if this problem was ever sorted as my sons is the same n i cant get it to work.
Having the same problem
having the same problem
I'm having the same problem after downloading new games. He's had this 3 years at least now and this is the first time it's happened.
