Tablets & eReaders Logo
Anonymous Posted on Dec 27, 2011
My coby kyros mid 1125 want unlock when i try to slide the unlock slider nothing i've tried to power down it want let me do nothing help please!!!!
I was on FB set talblet down bout 10 minutes come back tablet wouldn't do anything. I have hit reset button nothing. Can not power down.
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Dec 27, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
790
Points
12
Have you tried taking the battery out? That solves a lot of problems.
3 Related Answers
dj_relly999
dj_relly999
  • 4070 Answers
  • Posted on Oct 31, 2010
SOURCE: I purchased the coby kyros internet tablet from
Hi! As a first course of action, I strongly suggest that you look via internet for the driver. Hope this helps and thank you for using FixYa!
Anonymous
  • Posted on Jun 26, 2011
SOURCE: How to clear internet history on coby kyros
Go to your url box and click the bookmark button, choose history, press the menu button above your tablet, the one beside the home button. A clear history option will pop out, press it and your whole history will be erased. Hope this helps. :)
Anonymous
  • 59 Answers
  • Posted on Mar 10, 2011
SOURCE: i want to up root
z4 root one click root will permanently or temporarily root your tablet. Here are step by step instructions. z4 root is one of the simplest root utilities to use out there. It should be easy. Have fun and good luck http://www.androidtablets.net/forum/coby-tablets/6840-coby-kyros-mid7015-utimate-guide-rooting-android-market-clockworkmod-recovery.html
Cant remember my password
A really annoying issue but your password is Your and only you are supposed to know it.
So I guess your only choice is to do a Factory Reset of your Coby tablet:
Hope this Youtube tutorial might help you:
Factory reset on Kyros MID 7012 without using Settings
Also you should read these tutorial:
Coby Kyros MID7010 hard reset
http://webcache.googleusercontent.com/search?q=cache:eQiuI75ELTMJ:resetandroid.com/coby-kyros/+&cd=6&hl=es&ct=clnk
http://www.androidtablets.net/threads/how-to-factory-reset-on-coby-kyros.24344
You can get some more information doing a google search for
factory reset of Coby kyros Tablet
Coby kyros MID 7022 wont unlock main screen....swiping only meets halfway then screen goes black..help?
ok try the reset button plug the power cord before you start. look where is the reset and use a small point toothpick .
Forgot the pattern to my coby kyros
coby kyros mid:7036
how can i unlock my pattern
How do I factory reset my Coby Kyros 1125?
  1. Hold down the Power button for a short while to turn on the device.
  2. Go the Menu and find and select Settings.
  3. Choose Backup & Reset
  4. Select Factory data reset
  5. Select Reset device
  6. Select Erase everything
My Coby Kyros MIDI 1125 tablet is passworded.how can I bypass that to reset it?
This is the "master" reset procedure. No other way of clearing the unlock pattern.
*******This procedure will delete all items (file's) and entries on the unit******
Step 1- Power the unit off. Press and hold the "Power Button" image002.jpg till the "Device Option menu image003.jpgappears.
Step 2- Click on "Power Off image004.jpg and select "OK" image005.jpg.
Step 3- Once the unit has been turned off. Press and hold the "reset" image006.jpgbutton and "power" image008.jpg button simultaneously for eight seconds.
Step 4- The following screen image009.jpg will appear. Press the "reset" image006.jpgbutton.
Step 5- The Android system recovery screen image010.jpg will appear.
Step 6- The "Home and Menu" image011.jpg button will allow you to go Up and Down the Android system recovery screen.
Step 7- Press the menu button to go to "wipe data/factory reset". image012.jpg . Press the "reset" image006.jpgbutton.
Step 8- The following screen will appear. image013.jpg.
Step 9- Press the Menu" image014.jpg button to select "Yes- delete all user data".
Step 10- Press the "reset" image006.jpgbutton.
Step 11- The following screen will appear image015.jpg.
Step 12- Press the "reset" image006.jpgbutton to reboot/restart the unit.
My coby kyros mid8024 is dead! all it does when i turn it on is show "COBY" next i hear a clicking noise then all the lights for each button go out shortly after the "COBY" on the main...
It's sounds like it's down for the count. Take it to a repair shop. They may or may not e able tix it. Chances are good your going to have to buy a new device. I had that same problem and I ended having to purchase a new device .
15helpful
2answers
I need to download driver software for my coby kyros MID7015 so i can sync it to my pc
i have coby kyros mid7010-4g tablet
it just load the coby logo then penguin logo then android_ text
i tried the factory rest ( power + back + home ) ..
it gives " Unexpected updater mode! Please reboot your device.
How do i proceed from here Any help please.
Top Coby Tablets & eReaders Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Kolbrun...
Are you a Coby Tablet and eReader Expert? Answer questions, earn points and help others
