If you're pretty sure that your WiFi adapter is working then just reset your router.
Stick a pin or tip of a paperclip through a tiny hole behind the router.
Hold it for about 15secs until you see the power light turn off and
back on. Connect your computer to the router using an ethernet cable.
Open a Command Prompt and type ipconfig to get the router's default
gateway IP address.
Type that default gateway IP address on your browser.That will lead you to the router's settings log in page.
If you need any kind of technical assistance you can contact support cell at
http://www.vtechsquad.com/
