The ice maker is over filling the ice tray. The wiring harness is hanging down, I don't know where it attaches and I suspect this is what is causing the ice maker to malfunction causing the ice to stick together in a row when it is dispensed into the tray. I cannot find a diagram
I have the same problem, has anyone figured out how to fix it?
In most refrigerators - there is usually a small opening in the ice makers that regulate the water flow into the trays. With a small flat screwdriver --- turn the visible slot to the right to reduce the water flow time.
I'm having the same problem. Who has the answer?
Broken wires at the ice maker can cause that problem. It could be another temperature sensor as well of course. Check the ice maker temperature sensor for a cut or broken wire. The temperature sensor and rubbery gadget holding it in place often fall out of place when the drooping wires snag on the ice scoop or whatever. The sensor assembly is held in place by a wimpy plastic clip that breaks easily. Sometimes the wires get cut or broken when this happens.
After fixing this problem several times, I finally made a metal bracket from aluminum angle, drilled and tapped 4-40 holes in it, and drilled the plastic icemaker to mount it more permanently. I added a wire tie to hold the temperature sensor wire up and away from possible snag sources. The sensor wire and wire tie are not shown in the photo below, but if you have the tools to solder the wires and fabricate a bracket it helps a lot. It is easy to get the ice maker out, once you discover how to remove the drawer from the slides (two plastic clips at the rear of the slides).
Pull the front cover off, take out the two screws, and unplug the wire connector and it drops right out.
Ice maker assembly upside down on bench.
Aluminum bracket and screws
Bracket installed. The sensor is not shown in this photo, but the wire comes out the right side and crosses in front of the metal bracket. The wire tie holds it to the bracket near the top center (hole not shown).
