When you click on the market it says " Sorry, but your device is not compatible with AppsLib
Watch this Video: http://www.youtube.com/watch?v=6BrWSC2uiAg
The model he's using is the 7022, but the same procedure works for the 7125. Download the APK files that are linked in the video description and then connect you 7125 to your computer to copy them over. Once you have them copied, use the APK Installer that came pre-installed on your 7125 to load them. Make sure you load them in the order given on the video! I loaded them in the wrong order the first time and had to do a factory reset because the Back button (silver circle) no longer functioned.
Once you do all this you will be able to load the typical Android Marketplace and ditch the AppLib that doesn't seem to work.
