Depending on the model. Usually you can tell if it has one by the presence of a webcam. If yours has a webcam, just reload the Webcam drivers from the Advent website.
Shutdown the computer and disconnect webcam. Restart computer then after full boot, attach webcam and test to see if webcam works. If this does not solve the problem restart the computer with webcam attached. If this does not solve the problem then the webcam may be broken. If this is an internal webcam I recommend contacting the manufacturer.
is the webcam external or internal?
if the webcam is external - go google up "[brand name] drivers" and they should have one for you to download. for example, "logitech webcam drivers"
if the webcam is internal - go google up "[computer brand name] drivers" then go to the computer producer website and they should have drivers for you to download. for example, "dell drivers"
If you want to test whether your webcam works. you can try downloading skype and see if skype can use your webcam.
Sometimes the driver that comes with windows is better than the one from the manufacturer's cd. I would try both and whichever one functions better is the one to use.Good luck to you.
Depends on what error you are getting exactly. Here are some steps to solve webcam problems: http://www.pcauthorities.com/pc-errors/how-to-fix-webcam-problems
I had the same problem with my webcam and the best sollution i could come up with was to transfer all the files on the internal memory to the memory card instead, and the format the internal card so that you will have space on the internal card again.
The cam automatically assigns the internal as the primary source of storage so even if you switch it, it does not work properly.
Hey u forgot to mention if it an external or internal webcam. However, if it is an internal webcam; in the start search type as hp quick play or cyberlink youcam and select the second picture and u'll have the webcam option. Double click on it and u can see the webcam. If it is an external webcam insert the installation c.d and try to install the softwares which would be the Video impression and Photo impression. And follow the on-screen instructions. Hope this will definitely work.
Laptop: SONY VAIO running VISTA
Webcam is internal
When am trying to open my webcam using Yahoo Massenger...this popup shows ''The Webcam is not connected''...''Sorry no webcam was found in your system.''
