I dropped the lens and an inner ring broke. I am looking for the service repair manual so I could order the part for replacement.
SOURCE: I disassembled my Nikon 28-100 (3.5-5.6) lens...
Plastic next to the mounting ring, brass on top
SOURCE: My Nikon DX AF-S Nikkor 18-55 3.5-5.6G ED has a
You can get the part directly from Nikon, and the repair is fairly simple. Look at the step-by-step of the same repair done on this page:
http://www.gmtruckhq.com/artwork-design-forum/how-fix-broken-nikon-dslr-lens-mounts-3271.html#post125961
The part # and Nikon contact info is listed there as well.
SOURCE: I need the Picture schematic for my AF-S DX NIKKOR lens
hi i am SAGHA from mumbai,I do repairing from last 15 years. If I would have thought of repair manual for every camera & lens i would have one truck full with manuals.But practically speaking a littlebit of knowledge,lots of experience & very important high grade of your logic level,good memory & at last presence of mind these qualities will make you successful & perfect repairer.So follow these, go from mount side of the lens remove screws,distinguish them accordingly,keep them sequentially while opening,observe their locations minutely even before opening them, you will be sucessful definitely.I am giving you my key of sucess.Just follow & let me know.ALL THE BEST.Do not forget to vote me if you like it
SOURCE: I have a Nikon D50 which I frequently interchanges
without seeing pictures, I'd say you could TRY some plastic epoxy or some type of plastic-specific adhesive. i'm assuming you have the pieces that were broken off. otherwise, i'd say get a new lens...they are relatively reasonable used.
SOURCE: replacement rubber zoom band nikkor 17-55 2.8
yes...check with Nikon or I have seen replacement rings on ebay even...I'd check with nikon or a local nikon repair facility for parts..
