Archos Tablet 501582 Logo
chudaporn Posted on Dec 26, 2011
How to get appslib working?
When i go in All Applications it said server error, please check your connection. why is that ? my wi-fi are are working and everthing
How to keep Wi-Fi connection on XGody tablet?
Not a good make.
Wi-Fi Keeps Disconnecting on Android? 11 Ways to Fix
  1. Toggle Airplane On/Off. ...
  2. Check the Signal Strength. ...
  3. Forget and Re-add Network. ...
  4. Remove Obsolete Wi-Fi Networks. ...
  5. Restart the Wi-Fi Router or Modem. ...
  6. Reboot Android Phone. ...
  7. Disable Adaptive Wi-Fi and Adaptive Connections. ...
  8. Update or Reset Router Firmware.
More items...
Sep 22, 2022
2answers
Amazon Alexa Dot unit won't connect to the Internet while other WiFi devices connect fine. Doing the Alexa Dot Setup doesn't help. WiFi Router Modem was changed recently.
  • Plug your Echo Dot into a power outlet.
  • Open the Alexa app.
Saving Your Wi-Fi Passwords to Amazon FAQs.
  • Optional - Connect to a public network: Enter any required information if you are connecting to a public network that requires a web browser to sign in, like a school or hotel. The information could be a pre-shared password, room number, or just a button to accept conditions for using the network. This information cannot be saved to Amazon. Contact the network owner for more information.
  • Select Connect. After your device connects to your Wi-Fi network, a confirmation message appears in the app. You're now ready to use Alexa.
  • 0helpful
    I factory reset my zeepad, 7DRk-Q. Restarted the device. Wont let me sign in to any google apps.
    Please make sure you are connected to your network. Let us know? Thank you. Please leave feedback
    1helpful
    2answers
    Ok I asked the question three days ago why can I get on a free wifi connection with my phone but not my tablet
    The free Wi Fi router may have run out of IP leases on its DHCP server just when you were trying to connect the tablet. If the leases are as an example say one week long then if lots of people connect to the free wi fi they get a lease for one week. So if the device comes back within the week it already has an IP address assigned to it and works. If a new device comes along it has to ask the DHCP server via the WI FI to assign it an IP address. If all available IP addresses are leased from the WI FI router the device will not get assigned an ip address. Would suggest trying to connect the Tablet on another Wi FI system to test it works.
    I had this happen on my mobile phone when I was in Surfers Paradise in a Coffee shop and suspected the lease time on the WI FI router was too long for the amount of short term customers using the coffee shop. (the staff had no idea on why the Wi FI was not working so it would have been pointless to try and explain this concept to them and how to change the lease time on the dhcp server) Also there is a limit to the simultaneous number of users on a Wi Fi frequency on one access point . Unless the WI FI uses multiple WI FI access points.
    1helpful
    Cant get wi fi signal.
    Solution 1.Check wireless connection.
    The first step of diagnosis have to any other device connected to the same network, ensure the wireless connection is working fine, or verify the settings of your wireless router to correct it.
    2.Check your Keep Wi-Fi on during sleep Settings.
    Owing to Wi-Fi sleep policy your Wi-Fi connection may be going to get disconnected every now and then.
    Tweak this policy to keep your Wi-Fi connection awake.
    [Settings] >>[Wi-Fi]>>[Advanced]>> Check [Always] to keep the Wi-Fi on during sleep.
    Save changes and exit all the screens. Your Wi-Fi will never get disconnected again due to this policy.
    3.Check signal strength of wireless connection.
    The performance of a wireless network connection depends in part on signal strength.
    You have to connect the Wireless network where the signal strength is strong.
    Check Wireless network signal strength icons in notification bar.
    4.Try to turn off/on Wi-Fi on the device.
    First to turn off Wi-Fi, [Settings]>>[Wi-Fi] >>[turn Wi-Fi to off].
    And then to turn on Wi-Fi, [Settings]>>[Wi-Fi]>>[turn Wi-Fi to on].
    5.Try to forget network on the device.
    Forgetting wireless networks allow your tablet/phone to reset some settings.
    [Settings]>>[Wi-Fi]>>Press & hold your[Net Work Name(SSID)]for 2 seconds.
    >>Select[Forget Network]>>Re-Connect your wireless networks if it's disconnected.
    6.Try to reboot your device.
    7.Make sure your firmware is up-to-date.
    >>Select[Settings]>>[About tablet]>>[System Firmware Update]>>[Check Update].
    8.Try to reset your device.
    Note: once RESET was performed, all data, apps, settings and personal information will be deleted after initialization.
    Third-party programs might be the major probability of Tablet/Phone instable, suggested to have a full reset for the device if the situation persists.
    [Settings]>>[Backup&reset]>>[Factory data reset]
    9.Try to other wireless connections.
    If steps above were not able to solve internet connection problem still, please try other wireless connections if available, otherwise contact your networking provider to technical support.
    How do I correct a wi-fi error code?
    If there are any networks detected, forget that network. Then set it back up again with same network. If that doesn't work call your wifi provider
    1helpful
    HOW DO I activate my apple ipad A1432 to enternet
    Settings > Wi-Fi > flip the on/off switch ( when you slide the switch it will become blue ) > after Wi-Fi is on it will give you an option/options on which Wi-Fi server to connect to > click on one > see if your internet works then .
    Wi-fi- error
    Hello friend...
    Refer to your Internet service provider, if they provided your wireless router, or the router manufacturer, for additional help. Restart your Kindle and modem and/or router. Press and hold the Power button on your Kindle for seven seconds until the Power dialog box appears, and then tap Screen Off.
    For any Help visit us: www Kindle Com Support
    3helpful
    My apps libaray on my coby kyros mid7015 isnt working!!! everytime i try to go into the apps libaray it keeps saying that theres been an unexpected problem and that it has to "force close" why is...
    Sounds like you need to reset AppsLib.
    This fix will wipe all your data, so be sure to back everything up.
    Go to Settings.
    In settings go to Go to "Privacy".
    Select Factory Reset.
    Select Reset Device.
    Connect the unit to the computer using the USB cable and "Select" Erase Everything" The following will occur: • The screen will display COBY • The screen will display Android • The unit will reboot to the Menu screen
    Step 6- The unit will prompt to calibrate. Hold stylus on the center of the target. Repeat as the target moves around on the screen. ****DO NOT *** press Return or Home". The unit will display "calibrate success" and will return to the main /home menu automatically. If for any reason the unit went into standby mode and the touch screen does not respond, reset the unit using a pin.
    After the Factory Data Reset, do not launch the Applibs yet until: 1- You have configured your Wi-Fi 2- Check/enable "Unknown Sources"- Go to Settings, Application Setting. Done.
    You can now open appslib.
    12helpful
    My apps library is not working, says server errore,please checkconnection but connection is fine, what do I need to do?
    use the browser (google)
    type in appslib
    click download appalib ( new version ?)
    reinstall appslib
    i found this fixed the problem
    Top Archos Tablets & eReaders Experts
    SmartAviator
    SmartAviator
    Grand Canyon Tech
    Grand Canyon Tech
    Mike Cairns
    Mike Cairns
    Are you an Archos Tablet and eReader Expert? Answer questions, earn points and help others
