Power to the Front Panel?
A) The plastic front of your computer is the Front Panel
B) The area of pins sticking up on the motherboard, that the wires from the Front Panel go to, is the Front Panel header.
I believe what you are requesting is the Front Panel header pinout.
AsRock Support > AsRock 775i65GV Motherboard > Main Support Page,
http://www.asrock.com/MB/overview.asp?Model=775i65GV
Go to the headings on the upper left side.
Products, Motherboard Series, 775i65GV, Overview and Specifications, and so on. Click on - Manual
On the next page go across from the heading - User Manual, and click on - Click Here, under the country nearest yours.
Disregard if you are aware;
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click it may take up to 30 seconds before the first page comes up.
At the top of the PDF file is the page number box. It is to the right of the Down Arrow.
You can use the Down Arrow to arrive at the page you want, or;
1) Put your mouse cursor in the page number box.
2) Left-click once. (Contents in page number box will be highlighted in blue)
3) Type the page number you want in the page number box.
4) Press the Enter key
Go to Page 10
This page shows an illustration of the motherboard, and as it sits in your computer case.
To the bottom Right corner is the Front Panel header. It is marked by the number - 16 [ System Panel Header ( PANEL_1) ]
{ It is the second header over from the Right side. It is Black in color. The first header is a USB header, and it is Blue }
Now go to Page 22. Front Panel Header Pinout. (System Panel Header pinout)
If you cannot download this motherboard manual, or if you do not understand the pinout;
There are 4 pins across the Top row.
There are 5 pins across the Bottom row.
The Top row of pins are numbered Even
The Bottom row of pins are numbered Odd.
Starting at the LEFT side going to the Right, on the Top row;
Pins 2, 4, 6, and 8.
Starting at the LEFT side going to the Right, on the Bottom row;
Pins 1, 3, 5, 7, and 9.
A) Pins 1 and 3 are for the HarDDrive Activity LED light.
Pin 1 is for the Positive ( + ) wire.
IF the LED light is dim when operating, switch the two wires around.
B) Pins 5 and 7 are for a Reset Switch, IF, a Reset switch is used.
Pin 5 is for Ground ( - )
C) Pin 9 is Not Connected. (N/C)
D) Pins 2 and 4 are for the Power On LED light.
Pin 2 is for the Positive ( + ) wire.
If the LED light is dim, switch the two wires around.
E) Pins 6 and 8 are for the Power On switch.
Page 21 details out the USB front panel headers, (USB 2.0 Header, Shared USB 2.0 Header), and the Front Panel Audio Header.
For additional questions please post in a Comment.
Regards,
joecoolvette
