Uniden BC72XLT Handheld Scanner Logo
Posted on Oct 04, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Volume not working
The scanner works fine but the volume doesn't work. Any ideas what might be the problem? I can't find any thing in the manuel. Thanks
  • jlynns_03 Dec 25, 2008
    scanner works fine but no sound
Anonymous
Level 2:
  • Expert 90 Answers
  • Posted on Oct 09, 2008
Anonymous
Expert
Level 2:
Answers
90
Questions
Helped
56104
Points
151
If you mean that you can't turn the volume down, the problem is either a broken volume control or a broken connection to the "ground" side of the control. Either way, you should refer repair to someone knowledgeable about fixing scanners.
Computer volume works fine but Youtube volume just stopped working out of n where.
Uninstall the browser (if its not IE) and then reinstall.
Sep 21, 2013 • youtube.com
1helpful
Bravia kdl52ex700 volume control doesn't work
Look for any jammed buttons on remote, any obstruction like a sticker or gum on the sensor on the TV. If you have such obstructions, the TV will respond only partially.
Scans fine but no volume
broken wire to speaker, damaged speaker, bad volume control, it gets worse from there and requires a electronics specialist
1helpful
BC370CRS squelch not working
Take the case apart and clean the Volume and Squelch with Electronic Contact Cleaner until the knobs move really easy. The Potentiometers should now be clean and the Scanner should work as it should now.
Logitech S500 Volume Knob Broken
The simplest thing to try is some compressed air directed to the knob. This would clear out any dust or dirt that may be obstructing the knob. I am not sure what you mean by power cut so I am shooting in the dark here. If you mean a power surge that caused the volume to quit working then I would suggest an external volume control such as http://www.amazon.com/Koss-155954-VC20-Volume-Control/dp/B00001P4XH/ref=pd_bbs_2/002-2257004-6895258?ie=UTF8&s=electronics&qid=1194009359&sr=8-2
Or
http://www.radioshack.com/product/index.jsp?productId=2102975&cp=&sr=1&origkw=volume+control&kw=volume+control&parentPage=search
Tv ws-65511 volume stuck
Did you ever get this problem fixed? Ours just started doing the same thing. It worked fine the night before, but today it's doing what yours is doing. The remote stopped working for the TV. The remote still works for the cable box, but volume and anything related to TV function not. The screen flashes when we try to adjust volume or anything else, but resets to previous volume. TV not responding to any commands either on the front panel or remote.
Any ideas? Thanks, Patti
1helpful
Volume won't go up
CAMBIALE EL IC02 EEPROM 24C02 O EL 24C04 Y TE GARANTIZO QUE SALDRAS DE ESE PROBLEMA...
NO SQUELCH
I have a Radio Shack Pro 97 Scanner that I received as a present 1-1/2 years ago. It was working just fine and then suddenly there was no squelch or volume. The keys make noise when pushed, but there is no sound for the squelch or volume. The scanner scans the frequencies but does not stop and play. I went on line and found that other people were having the same problems. I went back to the store that the unit was purchased from and received no help what so ever, they said it’ s off warranty and I was out of luck, nice way to do business??. I think that something that cost as much as this should not be junk after a short period of time. I hope you can help me with this problem I do like radio shack, but I can’t afford to buy items that don’t stand up.
Sincerely
Greg Stevens
e-mail
[email protected]
Top Uniden Radio Communications Experts
John
John
eradiostore
eradiostore
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
