Question about Coby kyros Tablets & eReaders
I have a coby MID8024 tablet that will not connect to my wireless internet. I have checked the wireless and have no problem connecting with my other computers. I have gone to settings on my tablet and turned the wireless on and attempted to make a connection but continue to get an error code
    Master:
  • 665 Answers
You might have to do a Factory Reset in Settings.
Posted on Feb 03, 2018
SOURCE:
cdhardy
  • 111 Answers
SOURCE: cannot connect using wireless router
make shure that the wireless in enabled if so then update your drivers from here http://h20000.www2.hp.com/bizsupport/TechSupport/Home.jsp?lang=en&cc=us&prodTypeId=321957&prodSeriesId=376810&submit.y=8&submit.x=3&lang=en&cc=us
Posted on Mar 29, 2008
  • 17 Answers
SOURCE: I cannot connect to the internet. My wireless
Do you have anti-virus installed? You may have a virus that prevents you from surfing the net.
Also check if you are getting an IP address. Go to start>run>type in cmd and press enter. On the command prompt(black screen) enter in ipconfig and see if you have a IP address
Posted on Jun 04, 2010
  • 394 Answers
SOURCE: Ii have the Coby 7005
Hi, I am Steve, lets help solve your issue.
I am afraid the information you have been given is completely wrong. There is not such thing as plug and play in the android world. Android was initially developed for use on embedded devices and as such had no need to recognise external devices automatically. Version 2.1 (as installed on your device) is now quite old and cannot support it. Even the new version (froyo -2.2) does not support it.
Your device does come with a built in wireless adaptor, so you don't need a USB wireless adaptor.
Posted on Jan 15, 2011
Davethesnake
  • 689 Answers
SOURCE: I have a Coby Internet
these might be the initial stages of the re-flashing process ie:installing the OS or upgrading when you might connect a usb cable,im not familiar with your brand.
Posted on Mar 01, 2011
damneddle
  • 1607 Answers
SOURCE: I have forgotten my wireless
Hi!
In order for you to remove the password, you need to reset your wireless router. You didn't mention what brand and model of your router, but anyway all routers have a "reset button" just look for it on your router. It is usually found at the back of the router and it is very small, you need a pin or anything long and thin to insert into it in order to push it for about 10 seconds.
Thanks for using fixya!
Posted on May 30, 2011
How to fix kyros coby mid8024 tablet
Sounds like a corrupted kernel. The only thing you can do is download adb tools and then download the original Coby files for android. without having to do alot of research(if you dont know how to, you will have to research) you can go to Androidcentral.com go to the coby section, in the forum. There you should be able to find the step by step method. Sorry but this would be about the best help I can give you with out actually doing it myself.
May 10, 2015 | Coby Kyros MID80244G Tablet
How do i factory reset a coby kyros mid8024?
There are two methods of reset Coby Kyros MID8024:
1. Soft Reset
2. Hard Reset
Steps for Soft Reset:
  • Take out the battery.
  • Reinsert the battery.
  • Press and hold the power button for 10 seconds.
That's soft reset. If your device doesn't load after this, try hard reset.
Steps for Hard Reset:
  • Switch off the device.
  • Press and hold Volume Up + Home Button + Power Key.
  • After 2-3 seconds, release the Power Key.
  • You will enter boot screen, Select Wipe Data / Factory Reset.
  • Select Yes.
This will delete all the files including apps, personal data stored in phone memory. Don't worry it doesn't wipe off the SD Card so you should make a backup of your files stored in phone memory.
Apr 15, 2015 | Coby kyros Tablets & eReaders
I was not connect wifi with coby kyros tablet
Talking of setting up your connection, you mean the connection to a wireless access point you own. The wireless router must be yours, with your settings. You and only you should know the name f the connection and the way it is protected like WPA and the password.
If you don't have a wireless router, you can't setup a Wifi connection.
It is all in your manual belonging to the tablet and for the router there is a manual to. If you can't understand what one or both manuals are telling you it has no use typing here what is in the manuals. Please ask for help close by you.
Jul 23, 2014 | Tablets & eReaders
My coby kyros 8048 won't conncet to the internet after factory reset
Depends on the Android version you have on.
But commonly:
Settings (the pinion icon) > Wireless and networks > Wi-Fi setting (On). Then you select your wireless point and enter password.
Hope this helps.
May 14, 2014 | Android Coby Kyros Mid7014-4g 7" Tablet
What's authencation my tablet just keep flasing this and wont connect to internet my internet Web page says web page is unavailable Comcast is my internet provider please help me this matter.
its talking about your wireless password i'd guess.
i find sometimes electronics goes "tarded" and all you have to do is:
1) go into your wireless
2) long press it or something then select forget (please don't do this if you don't know your wireless password)
3) then reconnect and type your password again
I hope that helps
Sep 15, 2013 | Coby Kyros 716829701508 Tablet PC
Internet not connecting
  • Under settings on the tablet enable the wireless radio.
  • Once enabled you should get a list of available networks, select yours.
  • Enter any password you have.
  • If you get an authentication failed message and you know your password is correct, try disabling security on your network and try again. Some tablets have a problem with security especially those running ICS.
Dec 08, 2012 | Coby Kyros MID80244G Tablet
How do I connect to the internet using a wireless network if I don't know the password?
You should be able to contact your service provider and reset your password.
Feb 21, 2012 | Coby Kyros 716829701508 Tablet PC
How to I install the internet to my cobyMID7016? I had it working at one point, but now it will not load to my coby?
http://www.cobyusa.com/?p=faq#faqcat_8
on this page you will find almost all answers for your questions related with the tablet ..(under internet tablets sector )
The issue in your case it is the internet connection itself ..either the wireless network you used it is not working anymore or not on (if you use a router ) ..or simply you reset the tablet and you need to make the connection again ..Just open the internet connections ..(wireless card 0 ..and select to scan for networks ...and when you find your network ..select ti ..and than click connect ..This should connect it right the way ..
Also check if your internet network may need your mac address for to let you connect ..(this happens on the networks having the access restricted by the Mac address..)
to get it follow these :
  1. Click on Settings.
  2. Click on Wireless & Networks.
  3. Click on Wi-Fi Settings.
  4. Click the MENU button, located on the side of the unit.
  5. Click on "Advanced".
  6. Your MAC address will appear in the Advance Menu ..
same way to get to the connection for to activate just open wifi connections ..
Dec 26, 2011 | Tablets & eReaders
Can not connect coby kyros to wireless network my laptop is connected but it keeps saying out of range
Coby tablets are not compatible with WIFI "HOTSPOTS", HOTSPOTS use ADHOC networking, which the tablet doesn't support.
Dec 16, 2011 | Coby Kyros Tablet
My new tablet will not connect to internet. i have the usb plugged into mt laptop. i do not have a wireless router?
open network connections on your laptop and select both the wireless adapter AND the internet connection adapter in there and right click on them and click bridge connections. Then go into the network setup wizard (XP) or network and sharing center and click connect to a network and choose adhoc connection. then open wireless settings on the coby kyros and connect to the adhoc connection on your laptop. You should then be able to connect to the internet on it
Mar 26, 2011 | Coby Kyros 716829701508 Tablet PC
Tablets & eReaders Logo
119 people viewed this question
Top Coby Tablets & eReaders Experts
Kolbrun...
Andrew Taylor
Andrew Taylor
Are you a Coby Tablet and eReader Expert? Answer questions, earn points and help others
