My bluetooth wont play music from my blackberry
Hi Mike Cronk,
I see that you have a Bluetooth Headset and that you are tryingto connect it to your BB.
You mentioned it will not play or you cannot hear Audio From it from your BB?
Did the Bluetooth Headset sync to your BB? you need to make sure that the headset is sync properly on your BB and that the BB is dectecting your Bluetooth Headset. make sure that the BB is also set to be detected by any device for the Bluetooth to detect your BB as well for proper syncing of both devices.
try your Bluetooth headset on another devices as well see if it will sync to a different device just to see if the Bluetooth headset is working fine.
I hope this helps,
michaelvincentc
SOURCE: Remote funtions on LG HBS200 do not work with Blackberry Tour
When you go into the Tour's Bluetooth options, you can view which services are available for each paired device. Check the headset's properties and make sure all of the available services have a check mark next to them.
If that doesn't solve the problem, let me know and we'll try to find another solution.
