Microsoft Windows 7 Ultimate 32 bit Full Version OEM (Dell) Logo
Anonymous Posted on Dec 25, 2011
Windows 7 problem
Hi, I am experiencing problems with Explorer.exe. Whenever I am attaching the Seagate USB HDD it is flashing error as Windows Explorer has stopped working. Below are the details of the error - Problem signature: Problem Event Name: APPCRASH Application Name: EXPLORER.EXE Application Version: 6.1.7601.17514 Application Timestamp: 4ce796f3 Fault Module Name: kernel32.dll Fault Module Version: 6.1.7601.17651 Fault Module Timestamp: 4e2111bf Exception Code: c0000005 Exception Offset: 00047dd5 OS Version: 6.1.7601.2.1.0.256.1 Locale ID: 16393 Additional Information 1: 1d32 Additional Information 2: 1d32409995138d855a2b9bb446ccc159 Additional Information 3: 591c Additional Information 4: 591c8f267d7c87f1375dd28c7ce78903 Read our privacy statement online: http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409 If the online privacy statement is not available, please read our privacy statement offline: D:\Windows\system32\en-US\erofflps.txt Please suggest the resolution. Thanks, Amar
Tamer El Guoshy
Level 2:
New Friend:
  • Expert 135 Answers
  • Posted on Jan 09, 2012
Tamer El Guoshy
Expert
Level 2:
New Friend:
Answers
135
Questions
Helped
25608
Points
444
Try to connect the usb HDD in windows with safe mode(by pressing F8 while booting ) and try to check the HDD system disk by windows tool, this might solve some errors. and restart ur device & can work normally then, if windows found errors on ur harddisk & fixed them. good luck
Seagate ST91430AG not detected in Windows 7
people solved this same problem for both windows 32 and 64 bit hope i helped somewhat
@ lbsign fucknikco
^twitter (no spaces)
@ switchblades and *******
^instagram (no spaces)
http://www.tomshardware.com/forum/869-63-seagate-freeagent-windows
1helpful
2answers
I have plugged in seagate 250 GB seagate expansion portable drive into windows 7 but the disk is not detected. Can you help me how to resolve this ?
be sure power is supplied to the HDD, if and inter HDD change the cables, if is external check the USB cable and see if you need a complementary power brick or a second USB to power it.
My Seagate 500GB not detected in Windows 7. Fine in Windows XP
hi there,
how old is your hdd? it could be that your hdd did not come with support for windows 7. if that is the case, you will need to log onto the seagate website and download the latest software/driver for your hdd. hope this helps :)
1helpful
When i scan usb this error is found error
HOPE THIS PROBLEM IS autorun.inf virus PROBLEM
There is a much simple way to remove the Autorun.inf file. Genreally when you refresh the windows explorer view a bounded virus process recreates this file. This file is attached to many events of windows explorer including OPEN, REFRESH, etc. Simple stept to remove the virus activation:
You must close opened explorer windows.
1. open up a command prompt (i.e. cmd.exe) >> to load it go to Run, type cmd, enter.
2. Now to remove virus's attributes (in order to delete it type following line by line and execute them pressing enter.
e.g.
F:\
F:\attrib -s -r -h *.* If there are any malicious EXE files those are now visible so if unnecessary delete them too.
F:\del autorun.inf
3. After finishing above, quickly remove the pen as soon as posible (just after executing del command).
4. Now your pen is without virus activation config. file. Now you can safely delete unnecessary EXE files on it.
IF YOUR PROBLEM NOT SOLVE PLEASE KNOW ME If this answer helpful please vote me. Good luck.
Thanks for using FixYa
Hi I posted a problem last night about my asus eee pc 1005ha... kept rebooting at windows load screen. so I brought a dvd burner to run windows disk & do repar. it would go through everything fine...
Hi.
Solving your problem is just as easy as 2 hour work. not more..
By the time you were having the restarting problems.. all you had to do was to boot from usb cd-rom using Hirenes boot cd 10.
It starts a small intergrated windows. then you would have to go to a menu to stop some un-named startup bugs that cause the restart when Explorer.exe is being executed by windows.
so now, if you have your backups safe, get instruction on the internet on how to make a bootable usb windows vista or 7 Setup. windows seven comes with many drivers for new laptops.
Boot your computer from USB flash disk, run the windows 7 setup and enjoy..
hope this information helps you because it helped me with Acer One netbook..
good luck
After Seagate device not recognized, all flash drives gave troubl
even tho you have AV software installed , I wouldn't write it off so easily. Download and run Malwarebytes from
www.malwarebytes.org
and you may be surprised how ineffective AV software can be some times.
Don't forget to rate the advice!
http://www.aa1consulting.com
File missing
HI,
1. START> RUN > type CMD > now paste the following reg add
“HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon” /v Shell /t REG_SZ /d Explorer.exe
this procedure is to remove the error that comes whenever you restart windows
something like “could not find SSVICHOSST” or “error loading SSVICHOSST” or “windows cannot find ssvichost”
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
