why would any 8 year old computer be in warranty
love to hear that.
july 2010\ (first ones are 2009) carbon dated by me...
you posted 7 years later on this< why:?
lots of older PC the memories are not made, DDR1.
luck you its 3s.
#1 maker here.
try kingstone dot com
see none there.
leaving only used, and is real hard to find a match.
if you tech cant fix you PC then it cant be fixed can it.
he gave up. I know why, but he did.
he is smart,, is why
the correct path is a new or newer used PC
this is the only path
why, because to fix yours costs more. see.
here is your ram spec
- Dual channel memory architecture
- Two DDR3 DIMM (240-pin) sockets
- Supported DIMM types:
- PC3-8500 (DDR3-1066)
- PC3-10600 (DDR3-1333)
- Non-ECC memory only, unbuffered
- Supports 2GB DDR2 DIMMs
- Supports up to 4 GB* on 32 bit PCs
*32-bit operating systems cannot address a full 4.0 GB of memory.
kingson , links
CQ532OY
its a DESKTOP, luck you its not obsolete like on many older compaqs
ever like use goggle , i gave up at #1 kingston,
http://www.memorystock.com/memory/CompaqPresarioCQ5320Y.html
https://www.amazon.com/Memory-HP-Compaq-Presario-CQ5320Y-DDR3-10600/dp/B009BRRY66
here you shop
https://duckduckgo.com/?q=CQ532OY+%2C+memory&ia=web
