Canon PowerShot A520 Digital Camera Logo
Limor Cohen Posted on Dec 24, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
After initialization memory card and fix date & time, date & time are still 0
andrias
Level 3:
Master:
  • Canon Master 443 Answers
  • Posted on Dec 24, 2011
andrias
Canon Master
Level 3:
Master:
Answers
443
Questions
0
Helped
66621
Points
1021
You may have to enitial the time and date wen you set it
2helpful
2answers
My 2gb sd memory card showing 0 bytes
Lost data on the memory card? You can recover data with memory card recovery software.
Tenorshare Data Recovery can recover lost,corrupted,deleted or formatted data from memory card,memory stick of digital camera,mobile phone,camcorders etc.If needed,download it and scan your hard drive for free to preview whether your files can be recovered.It will show you the file name,type,date and size of your files and thumbnails for your pictures that it found on your drive.You can get it from: http://www.any-data-recovery.com/product/index.htm
Find driver easy tv captuer saa7130hl
http://download.cnet.com/Philips-SAA713X-Hybrid-Capture-Device/3000-2110_4-156884.html
if this does not help try www.driverdetective.org free to scan your computer if it finds your driver you will have to pay to download
I scaned file it looks clean but you should save it to your desktop and scan it also. G.L.
Malwarebytes' Anti-Malware 1.50.1.1100
www.malwarebytes.org
Database
version: 6326
Windows 6.1.7601 Service Pack 1
Internet Explorer 9.0.8112.16421
4/24/2011 2:14:55 PM
mbam-log-2011-04-24 (14-14-55).txt
Scan type: Quick scan
Objects scanned: 1
Time elapsed: 1 second(s)
Memory Processes Infected: 0
Memory Modules Infected: 0
Registry Keys Infected: 0
Registry Values Infected: 0
Registry Data Items Infected: 0
Folders Infected: 0
Files Infected: 0
(No malicious items detected)
Nortons insite scan
Scan Statistics:
Scan Time: 1 seconds
Scan Targets: C:\Desktop\Temp download\Drv_ATSC110_Philips_V1.3.3.2.zip
Counts:
Total items scanned: 78
- Files & Directories: 78
- Registry Entries: 0
- Processes & Start-up Items: 0
- Network & Browser Items: 0
- Other: 0
- Trusted Files: 1
- Skipped Files: 0
Total security risks detected: 0
Total items resolved: 0
Total items that require attention: 0
Resolved Threats:
No risks have been resolved
Unresolved Threats:
No unresolved risks
Hi , i've HP ML370 G4 server , after power failure , the server can't boot . i try to reinstall memory & remove all parts & fix it agian but the problem still there , then after about 1 hours it's...
It may be that the lithium battery is dead; usually a CR2032 button battery. Signs of CMOS Battery Failure Dom Tech Computer Blog
Go into the BIOS settings during initial power on boot up, often F10 or F2 are common. Check the date and time, if they are off, you should be able to temporarily boot by setting the date and time but you'll have to do it every time you boot. If the date and time is off, and you set the correct date and time and it still doesn't boot, you'll want to make sure it's booting to the correct drive.
When it doesn't boot, does it give you any error?
2helpful
When i turn camera on get blue screen that has date and time than in black letters i get lens error 221,0,0,0 and camera goes off
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success.
I just purchased this camera and inserted a memory card. Now, when I try to take a picture, I get the 'card protected' error. How do I remove this error and take pictures?
Without knowing the make and model of this new camera I can only speculate on the problem however in my opinion you need to unlock the protected card I'm giving a diagram of an SD card here.
Slide this little switch to the top or towards the gold contacts.
Another thing you will need to do is format the memory card your camera may call this initialize.
Formatting a memory card makes it ready to accept information files from the camera. I hope you have your manual because without knowing the camera make and model i can only suggest where to look for this feature. Most often this function is in the set up menu, once the card is unlocked you need to find this format highlight it and press the okay button once done the camera will function properly as long as you have set the day date and time. Day date and time once set is held in the camera internal memory so you don't have to input the information each time you turn the camera off and back on again. Happy New Year
Dec 31, 2010 • Cameras
I can't on or off my l19 camera and the lens is always coming out.display is blank.
Issue with Ic Prologic.. Fail to initiate ..Camera got drop.. Board defect need service ... Try To...Take Battery off for 5min then put back on the battery then try to set date & time ..Sometime your have to set date and time before the screen apear ...if it so change your Battery memory inside the unit check on the main door battery for slot mini battery for memory
My Kodak (SD Card 512MB) Memory Card Says Not Initialized ?
Pls. format the card.
Check if CD card lever is down/up
Test w. a different SD.
If your SD card is faulty there is a warranty on it.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Using my memory card, i check my photos display with out date & time.
You will find a setting that will date/time stamp the actual image when it's taken. Please take a look in your manual. Most cameras have this feature.
6helpful
5answers
Camera keeps resetting the settings when turned off
Possible solution?
PROCEDURE
1. Initialize the system.
a) Enter the TEST mode.
b) Select "3:ROM UPDATE" and press SET button.
c) Next, select "5:SYSTEM INITIAL" and press SET button.
d) The following message appears.
SYSTEM INITIALIZE
START ...
PUSH OK KEY?
e) Press SET button and System is initialized.
"SUCCESS !" appears on the monitor.
2. Write firmware.
Update the firmware version"
Write the firmware.
If the TEST mode boots automatically, change "USB TCC ON" to "USB TCC OFF".
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
