It is a common problem with any universal remote controls. Try an other code for your device. Select one code which has maximum functionality. Than is the only thing have to do.
Codes to Samsung DVD/VCR are: 0455 0963 Buy one universal remote control, which have these set up codes for its DVD/VCR codes list. You can get this detail from the code list attached with the remote control.
Because this product is a combination of a VCR and a DVD recorder, you must select first which component you wish to operate with VCR/DVD DVD mode Press DVD on the remote control. Verify that the DVD indicator is lit VCR mode Press VCR on the remote control.(Verify that the VCR indicator is lit OR I set up this pdf link...click on it and it will show you all necessary steps http://www.helpowl.com/manuals/toshiba-dvr670-owners-manual-english-70453af.pdf
You just have to match the color of the plug to the color connector on the TV and on the DVD.
Look for something like AV1, or Video 1 on the TV. It should have Yellow jack for the Video, and RED and WHITE jack for the Audio Right and Left channels, same thing applied to the jacks on the DVD player.
The just select AV1 using the remote control, just look for 'INPUT', or 'SOURCE' bottun on the remote.
If the entire VHS is full then you can easily transfer the VHS contents to the DVD. The video will play while it is recording onto the DVD, but you don't have to have it hooked up to any TV for it to record. Now if you don't know how long the VHS content is that you want to record to DVD, then you will have to hook up the player to a TV so that you can press stop when you reach the end of the content you want recorded. At least this is true in the way that I use to transfer VHS to DVD:
1) Turn on the unit 2) Insert VHS tape 3) Insert DVD-+R or DVD-+ RW 4) Using remote, press VCR 5)Using remote, press play then pause the tape where you want to start recording. 6)Using remote, press DVD 7) Using the remote, press DUBBING. The VHS should start to play and the DVD should start recording
When using this method, don't hit the RECORD button!
If the buttons on the case are working but the buttons on the remote don't then it's clearly a fault with the remote.
Each button in the remote is made out of 2 wires on the electronics board that are joined by a small patch of conductive paint situated on the rear of the rubber button. If something gets in there, like water or dirt or the patch flakes out, the contact is no longer made and the button no longer works. The remote will have to be dismantled by popping the clips on the periphery with a sharp tool, the rubber strip holding the buttons will have to be washed and the board wiped clean. If the buttons still don't work after that then the remote is dead, you will have to get another one.
This is not an issue with the drive. The drive is not what tells your pc to play movies automatically. Anyhow, I don't know what version of windows you are using, but if you click start-help and then type in 'auto play' it will show you how to change the settings so movies will play automatically. Also, if you don't have it already, install VLC media player.....it plays pretty much any video files.
Not much you can do without a remote for this model except play 1 disc (CD or DVD) manually at a time. You could try to obtain a replacement of the original remote directly from Panasonic, or you can look again for your lost one in your home, or you can try a (cheaper) universal remote with this unit. The cost depends on what type of remote you get and where you buy it from (if you order through Panasonic there may be an additional shipping charge). Sequential play (one disc after the other automatically) usually can only be set using the remote.
The fact is, this player needs a remote for full functionality If you want random/sequential play for multi discs, the original Panasonic remote is required - try ordering this first if it is available. If not, then consider a universal. (you could also look on eBay for a similar DVD player remote for this model)
You will need to finalize the disc.
Put unit in 'DVD' mode than press 'HOME' on recorders remote than go to 'START-SETUP' go down to the 'DISC' icon press 'right arrow' on remote, highlight 'finalize' and press 'ENTER'.
