Washing Machines Logo
Anthony Wright Posted on Dec 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
FEW 12 will wash and drain but wont spin - General Electric Washing Machines
Anonymous
Level 3:
  • Master 8,619 Answers
  • Posted on Dec 23, 2011
Anonymous
Master
Level 3:
Answers
8619
Questions
Helped
2150348
Points
26471
Hi
Thanks for using FixYa. Please check if some small clothes have been stuck in the water pump. If so, please take them out and clean it. The Water Pump is mounted directly to the motor. If still the issue persists, then it seems that the drive motor has gone bad if it fails to start after the water is filled up to the required level and if the motor is running but the agitator is not moving then it means that the drive motor belt is excessively worn. Please check and replace whichever is required. Also please check and reset the circuit breaker and check the fuse. Please remove the debris from the drain hoses and the drain. If it is clogged, clean it. Now close the door and press start/stop button and it will start to spin after the door is locked. Please revert back for further assistance.
Thanks
Rylee
My washing machine will'nt wash and little water come out to fill it
Washing Machine Will Not Agitate or Spin - Home Repair ...
? 15:00
www.youtube.com/watch?v=wUSmUSWWIS4
Oct 20, 2013 - Uploaded by Robert DIY This washing machine would not agitate or spin. There is a ...My washer also is not agitating or spinning but water will drain after a long while.
Troubleshooting Why the Washer Won't Agitate ' PartSelect ...
? 3:10
www.youtube.com/watch?v=LfWRyt1vj2w
Nov 5, 2012 - Uploaded by PartSelect
The only wash cycle that works is delicate none of the other washcycles work .... The washer still fills, drains and spins to dry butwill not agitate. ... Hi My machine wont spin or agitate on heavy loads like a few towels etc (fine
Why wont my home comfort 1401 washer drain but not spin
There are many things that can stop it from spinning....but the
first place to check is the belt. Is it loose or broken?
Whirlpool WFW9050XW Washer Front Load
Disconnect your mains from the wall and clean out your filter.
Pl click if helped.
Why wont it spin and drain
if its a front load washer check the drain pump,if it cant drain the water it will not go into spin cycle,depending on make/model the pump can either be accessed from the lower front or rear areas under drum inside the machine
Washer wont drain. fills with water. goes through wash cycle but wont drain. once it gets to the spin cycle, it spins for a few seconds and then stops and rinse light comes back on.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
It wont empty out completely clothes are still. The drum itself is very loose not sure if it suppose to be that way. It does not spin very fast . does this particular model have a belt that needs to...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
7helpful
2answers
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
1helpful
2answers
Bosch wfd2473 washing machine wont drain or spin
I have a bosch wfd 2473 washing machine...wont drain,I have had this problem before and resolved it by removing drain/filter plug...normally a button or hair clip....but this time there are no objects blocking.I am guessing the drain pump is faulty and needs replacing...?????
2helpful
2answers
Will only fill and drain
It sounds like the timer/controler is broken replace it. Peter
2helpful
2answers
Kenmore Washine Machine does not drain
sounds like a bad lid switch, agitates but doenst advance to rinse, remains full of water?? if so lift the lid up and downa few times hear a "clicking" noise??machine doesnt think lid is closed so for safety reasnos wont spin/drain replace the door latch
Top General Electric Washing Machines Experts
Paul Bade
ADMIN Andrew
ADMIN Andrew
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
