SOURCE: Magnavox 42 LCD 42mf438b/f7 turns on/off by itself
I have exactly the same problem with a Magnavox LCD 42", very similar model 42MF437B/37. I don't have a solution. If you unplug the TV and plug it back it starts working, sometimes for hours, sometimes for less than 5 minutes, before it turns off again. Does anyone have any real solution?
SOURCE: Codes for sharp TV VCR comb and magnavox TV DVD combo for use with URC-4021B00
0274,0271,0268. Check these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
SOURCE: Need codes for sharp TV VCR combo and magnavox TV DVD combo For the all in one urc4021B00. Please
If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
Code list to many popular brand remote controls are given.
SOURCE: I have a Synergy v ,direct tv remote control and i can't program myoldermagnavox tv/dvd/vcr combo
0080 0090 0145 0161 0221 0232 0247 0384 0407 0454 0631
SOURCE: How do i program a magnavox tv/dvd combo with a magnavox universal remote?
If it is its original remote control; no set-up is needed. Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the relative post easily.
brand new, out of box. Plays audio cds, NO DVD's. Tried over 10 different DVD's now.
